Question about Vizio VO47L 47 in. LCD TV
Buzz sound out back - Vizio VO47L 47 in. LCD TV
    Top Expert:
  • Vizio Master
  • 74,630 Answers
Hello
That sound comes out from the power supply regulator board to your tV. Replace it as card basis. There is no repair to this baord. Its SMPS transformer makes the noise.
Posted on Feb 25, 2012
Buzzing sound coming from under the back end
Under the left side of your back seat is a fuse / relay box . When you first turn the key on the fuel pump relay turns on for a few seconds to prime the fuel system . That relay is in that fuse / relay box ,that is what your hearing . Does the vehicle start an run good , no problems other then the buzzing sound .The vehicle battery is also under the rear seat on the right side . How To Locate and disconnect Battery Buick Lesabre Pontiac Bonneville 00...
Feb 19, 2016 | 2002 Buick LeSabre Custom
I purchased the 16 inch Ultimate Buzz Lightyear for my grandson, and it seemed to work fine, but all of a sudden he quit speaking. His lips continue to move, but no voice is coming out. We have changed...
We had the same problem - sound got quieter and quieter until Buzz was mute. My husband gave Buzz a sharp whack on his back where the AAA battery compartment is located and Voila - Buzz is speaking again.
Jun 08, 2011 | Disney Pre-Order Ultimate Programmable...
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Buzzing at my cell phone near the flexible
remove the battery... and dont return it so that the buzzing wont come back....
Feb 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Buzzing
The noise is caused by dust on one of the toroidal transformers(usually a round looking thing with wire wound around it). Go to the back of your television and try and pinpoint were the sound is coming from. Turn your television off and blow it out with compressed air if it is close to air vents in the television. If you cant see it you might have to open your television back panel.
Nov 23, 2006 | Panasonic TH-37PE30 37 in. Plasma...
Vizio VO47L 47 in. LCD TV Logo
102 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
