Question about Kyocera X-tc Cell Phone
How do I charge it?
I can't figure out how to plug it in!
Read the manual here http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-x-tc.pdf
Posted on Nov 21, 2013
Electrical short?
Not a short.
Either the circuit to the battery light is bad, or the fuseable link on the starter solenoid is toast. There is a 30 amp fuse in addition to the fuseable link, plus a 15 amp fuse on the circuit for the battery light.
All of these circuits need to be tested.
Aug 30, 2012 | 1993 Mercury Grand Marquis
How long do you charge battery after you've done initial charge
a good rule of thumb is one hour for every amp hour that the battery is, so if its a 12ah battery then charge it for 12 hours
Jul 14, 2012 | Fisher Price Fisher Power wheels Cadillac...
How do I charge this?
You've probably figured this out by now, but their should be a thing that looks like the male end of an electrical plug in an odd place. Get an extension cord and place the female end over that male end and plug the male end of the extension cord it into the wall overnight.
Jul 05, 2012 | 450 Amp Battery Jump-Starter
I have changed 5 alternator in one day which where no good...I checked my 175 mega fuse it is ok i check the 30 amp fuse which had a 10amp fuse changed it to a 30 amp fuse but made it worse.. also check...
Five bad alternators in a row borders on the incredulous. 2, 3 maybe, but 5 is a Guinness world record! I have to ask the 30 amp fuse made what worse? Is it not charging? Have you tested the battery? Maybe it has a dead cell, won't take a charge. Recheck battery connections and grounds. Test the battery or try a different good battery. What testing tools are you using?
Jun 21, 2012 | 1999 Ford Explorer
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
Hello.I've got an Asus K52JE.Today I looked at the
97% isn't that bad, it means that your battery is fully charged but not the whole way. That is bound to happen specially when youre using youre battery a lot. It will get a lot more lesser in the future the more you use youre battery.
The standard laptop battery starts losing the ability to hold a charge after 300 recharges or cycles. If you drain your battery almost completely at least once a month and then recharge it, it will last longer & hold a full charge longer.
Jul 09, 2011 | ASUS Computers & Internet
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Given a hand me down Dexton Lil Driver Battery Golf Cart. Is there an online manual to find out what the charging cord looks like & where to plug it into the cart.
To charge... you need to remove the seat. Only 2 screws holding it in place. Underneath you will see the battery...you will notice wires from the battery connect to wires from the motor on the wheels...pull apart those 2 connectors and attach the charger...then plug it in to a wall socket and leave connected for a long period of time. I don't remember how long it takes for a full charge...but I'm thinking at least 12 hours. If the battery doesn't hold a charge you can typically get it at walmart or online. Best of luck.
Jan 30, 2011 | Toys
Kyocera X-tc  Cell Phone Logo
49 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
