Question about Pyle Pt3300 Amplifier
Broken display on PT3300
The level meter in the middle of the amplifier face no longer lights up. It seems like a new PC board is needed to remedy the situation
    New Friend:
Mine came in the mail today and it did that already so i hope it is'nt that
Posted on Apr 10, 2013
How do I adjust contrast?
There are Function Keys to do this.
from Troubleshooting section. Keyboard (if contrast and brightness function key)
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
and Page 10 of the manual
Display Keep your display clean. • Keep your head at a higher level than the top edge of the display so your • eyes point downward when looking at the middle of the display. Adjust the display brightness and/or contrast to a comfortable level for • enhanced text readability and graphics clarity. Eliminate glare and reflections by: • placing your display in such a way that the side faces the window or • any light source minimizing room light by using drapes, shades or blinds • using a task light • changing the display's viewing angle • using a glare-reduction filter • using a display visor, such as a piece of cardboard extended from the • display's top front edge Avoid adjusting your display to an awkward viewing angle. • Avoid looking at bright light sources, such as open windows, for extended • periods of time.
http://www.manualslib.com/manual/205261/Acer-Aspire-3680.html?page=10&term=contrast
Dec 27, 2015 | Acer Aspire 3680 Laptop
Fan is running, oven seems to still be heating, but no lights on display
If other electrical components are working, then you probably have a bad display module, or possibly even just a ribbon cable between the display and the main circuit board that got pinched and is no longer transmitting power or data to the display.
If you can remove the ribbon cable you can use an ohm meter to determine whether there is a broken wire by touching the two ends of each wire with the leads from your ohm meter. If the ribbon cable is working properly, then it's time to replace the display.
Indicating the make/model of the appliance would help others to identify replacement parts as well as provide instructions on how to remove panels to access those parts.
Mar 04, 2015 | Ovens
What is the main tranformers number for pt-3300pyle pro
It will be written on the transformer, but you will only be able to get an exact duplicate at Pyle.
May 08, 2014 | Pyle Pt3300 Amplifier
Ga-h61m-s2v-b3 not coming on using power switch
I agree with Mike, but would like to add a couple of things. I had the same problem with a Gigabyte board (new install) and found that I had to change the CMOS battery. I put in a new batter, and "voila" it worked fine after that. Also, not knowing your level of experience, make sure the front panel connections are on correctly. Generally speaking, if you look at the lettering on the plastic ends that plug into the board pins on the front panel connector, the lettering should face the edge of the board and not be facing the middle of the board. That too has caused a similar sounding problem in the past. Other than these two potential solutions, more information is definitely needed.
Mar 20, 2014 | Gigabyte Motherboard Ga-H61M-s2P-B3 Core...
For some unknown reason the db meter on the display stopped working and the volume wont go up very high at all?
Got a feeling that this amp might be powered by a big IC somewhere that's failed. Perhaps something looking like this:fffa1d0d-4877-4ce2-b3fa-89d116a21d5f.jpg
Apr 09, 2013 | Pyle Pt3300 Amplifier
Need voltage level on dial lamps for a Mitsubishi DA-C20 PreAmp.
I don't have one here to verify, so the easiest way to determine this is to actually measure it using a volt meter. These "fuse type" bulbs are readily available from mcmelectonics.com (and others too). Follow either the wires or the traces for these bulbs on the board. Some units have 2 in series. These are either 6,8 or 12V bulbs. If memory serves me correctly, most mitsubishi units use 12V bulbs.
Keep us posted.
Dan
Apr 03, 2009 | Audio Players & Recorders
Picture and colour problems
Your DMD board is bad.. I had the same problem. It went away with a new DMD board.
Mar 16, 2008 | Televison & Video
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Pyle Pt3300 Amplifier Logo
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
