Nashuatec Dsm 618 displaying error sc:552 please help me how to clear it
Nashuatec photocopy machine
  • 37 Answers
SOURCE: REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Posted on Aug 14, 2008
SOURCE: how to clear error code,sc542 nashuatec photocopier-mp6500
nashuatec 2205 Aticio problem cod SC 542
Posted on Apr 15, 2010
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
santosj27
  • 263 Answers
SOURCE: I have Nashuatec SDM 616 photocopier. I was doing
This code is related to a current leak in the Charge Roller.
The first thing i advise you to do is clean the plug of the PCU (fotoconductor unit) and of course the PCU.
If you take out the PCU you will see a metallic pin and a spring (in the back of the machine). Clean it or vacuum it (could be dust of toner).
This should be it.
If that doesn't work you probably have a defective High voltage supply board.
Hope that helps
Posted on Mar 03, 2011
joel_baleta
  • 155 Answers
SOURCE: error sc 326 in dsm 635
First of all check that the laser **** glass is still there, I've seen a couple of machines where the **** glass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
Posted on Sep 23, 2011
What Could Be The Failing Component On My Machine With Displays SC: 552 With An Error Message "Turn Off Main Switch And Then On" ?
I am no expert, but it potentially could be a memory chip error being a laser printer, very common, these can be easily and cheaply be replaced as there is usually an access hatch to the side printer memory isn't usually very high capacity
Jun 15, 2014 | Ricoh Nashuatec MP1600 Toner 9000 Yield...
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
I have Nashuatec SDM 616 photocopier. I was doing copies when give an error code of SC:302. Please explain the code for me so that my service can use it to service the machine. Thank u
This should be it.
Hope that helps
Mar 03, 2011 | Gestetner - DSM-616 COPIER Copier
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
160 people viewed this question
jasbo
jasbo
