Just repaired 3 benq fp767 lcds replaicing blown caps on the inverter board and was able to get one running very nice. The other two show the Benq logo for a few seconds then show my desktop for a few seconds then nothing on the screen
Samsung 204BW Replaced blown caps on the inverter board and burned in for a day and 1/2 then the...
(More)
Samsung 204BW Replaced blown caps on the inverter board and burned in for a day and 1/2 then the screan3/4th the way up from the bottom went white then the other 1/3 went negitave. Now I have lines going across favering 3 pictures top to bottom.I've seen bad caps in a vertical section in a tv or older monitor cause something like this. But not a LCD.???? any leades to what it might be? Bad LCD driver transformers??
The bracket(s) holding the monitor on the stand appear to be bent such that the monitor only points...
(More)
The bracket(s) holding the monitor on the stand appear to be bent such that the monitor only points downward. Is there any way to take the monitor off the stand and replace the brackets?
Syncmaster 204bw purchased thru Dell. The screen is black, on button flashes 0nce per second...
(More)
Syncmaster 204bw purchased thru Dell. The screen is black, on button flashes 0nce per second (roughly) continuously. pressing it on or off , no help. unplugging ( left unplugged for more than 10 min_)or changing power cord no use. hooked old monitor to computer, everything ok. What is wrong with the samsung 204rw, and is it fixable at home. its around a year old
My Samsung SyncMaster 204BW monitor used to let me display at a resolution of 1680x1050. Now, I...
(More)
My Samsung SyncMaster 204BW monitor used to let me display at a resolution of 1680x1050. Now, I can't select to set it at that resolution (I can to choose between 1440x900 or 1600x1200 among some other smaller resolution options but that is it). I have no idea what changed and I have no idea why this is happening.On the monitor itself it says that the choice of resolution is not optimal and recommends 1680x1050. Can you please help me understand why, all of a sudden, this has become a problem? I'm not sure if this has anything to do with it, but under the display properties->settings tab, if I click on the pull down menu, both options say (Multiple Monitors) on ATI Mobility Radeon X1300. Maybe this has something to do with it? I also occasionally switch out the monitor for my TV (I only have one VGA slot on my laptop and I'm using VGA to connect the second monitor). My settings for the TV are different and maybe my laptop is getting confused? Again, just some more details that may or may not be relevant. Thank you.
I attached a Samsung SyncMaster 204B to a MacBook. The MacBook is seeing the monitor, but the...
(More)
I attached a Samsung SyncMaster 204B to a MacBook. The MacBook is seeing the monitor, but the monitor is still in stand-by (turn-on button is blinking). How can I get the monitor working?
