I HAVE A DENON AVR 886 AND WHEN I TURN IT ON IT POWERS ON SCANS THE CHANELS AND THEN SHUTS DOWN.I UNDERSTAND THAT THIS IS A COMMON PROBLEM BUT HOW DO I FIX IT
  • 3 more comments
  • Anonymous Nov 17, 2008
    Denon 2105 amp.
    symptoms, switch on green led flashes 4 secs then red flashing "Protection Mode".
    Tried the following:-
    reset using a+b buttons.
    replaced ic101 ic102 1c104. (+15/-15/+5 volt regulators).
    Checked r184 10ohm resistor OK.
    Unsoldered and measured all 21 output transistors. All seem ok.
    Checked for dry joints, any suspects esoldered.
    All tests carried out with no inputs or outputs connected.
    Found 10mfd 50volt and 100mfd 10volt electrolytics in one of the preamp channels very low capacitance, replaced.
    checked all capacitors in power supply and all on pre-amp board for capacitance value and ESR, all ok.
    checked +/- 53 volts at collectors of o/p stages before protection operates, all ok.
    all buttons and knobs operate at switch on before protection.
    What can I try next. have all necessary test equipment but no circuit diagram. Can you help please. Regards Alan.
  • alang4vou Nov 17, 2008
    Model avr-2105
    Symptoms:- switch on, 4 seconds later red led lashing "Protection mode".Display ok and all
    buttons/knobs work ok for 4 seconds.
    Tried Reset a/b plus switch on.
    replaced ic1-ic2-1c4.+15/-15/+5 volt regulators.
    Checked r184 10ohm ok
    found 10mfd 50volt and 100mfd 10volt capacitors in one of the preamp channels low capacitance,
    replaced.
    Unsoldered and checked all 21 output transistors (2sd2390/2sd947f/2sb1560) all appear ok
    checked capacitance value and esr of all capacitors on preamp board and power supplys, all ok.
    Checked for dry joints and resoldered anything suspicious.
    no inputs or outputs connected during testing.
    Do not have service manual or circuit diagram so not sure what to try next, can tou help please.
    Originally went off due to playing too loudly for 1 hour.
    Regards Alan.
  • imoda4 Mar 09, 2009
    I get the red flashing light as well. I recently moved my amp and speakers. When i powered it up again i was running it fairly loud for about 5 mins then a series of blue flashes came out of the amp and a puff of smoke. I checked all my connections and found one wire on the right front speaker had come out at the speaker.
    I have taken the cover off the amp and removed the preamp board. Ii can see the fried components. They are on the bottom mother board located between the preamp and amplifier heatsink. R115C is half missing and the surrounding components R 117C, Q104C, C105C and D143 are a bit off colour but might just be from adjacent arcing. So my question is if ireplace theses components is it likely that it will fix the problem or are they just a part of a much bigger problem. any help much appreciated.
  • farmersgroup Mar 11, 2009
    I have the same problem. How can I find R184? Thanks Dave.
  • Anonymous Mar 19, 2009
    what is the value of R115 please?
    President:
  • 624 Answers
It is going into protect mode. It is a common problem, but is not an easy problem to fix. It will go into protect for 3 main reasons. I work at an authorized Denon service center and have repaired many of these models, so I know what I am telling you is correct.
Reason 1
The receiver has a blown channel. This will require the replacement of many parts. The output transistors, supply resistors, driver transistors, and a capacitor in the driver circuit of the affected channel. It is usually the channel that is located closest to the display board on the main heat sink.
Reason 2
A bad voltage regulator in the power supply. It has several voltage regulators all on their own small heat sinks. It is usually ref # IC101 or ref # IC102.
IC101 is a positive 15 volt regulator and IC102 is a negative 15 volt regulator. More often than not, it is the negative regulator that has gone bad.
Reason 3
The amplifier circuit has a 10 ohm resistor that supplies a high voltage to it and that resistor opens up and must be replaced. It is ref # R184. It is a 10 ohm 1 watt resistor.
Those are the 3 main reasons for your problem. It is not an easy unit to fix, but it is well worth the cost of a repair considering how much these receivers cost to purchase a new one. If you do not have the proper tools to fix this unit, please do yourself a favor and have a service center fix it for you. You will need a multimeter, soldering iron, solder, solder wick, and a # 2 phillips screwdriver. You will also need to isolate whcih of these 3 problems is causing the unit to go into protect. If you have a multimeter I can help you with it, but you still need the soldering equipment and must be skilled at using it.
Let me know if you require more help,
Dave
Posted on Oct 28, 2008
  • RJ Brossart
    RJ Brossart Jun 10, 2017
    Hi Dave. I have a similar problem with a Denon AVR-889 that I picked up for cheap on Kijiji. I replaced the blown transistor D2560 but I think the 7815 voltage regulators are reading quite high voltages. The 7815 VR's are IC801 and IC803 are both reading 42V in and 27.9 Should I replace both of these, or should I follow further upline to see what else might be causign the issues. It would be great to get this working again....keep this from becoming more e-waste in the landfill. Any thoughts would be greatly appreciated.
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
My receiver keeps shuting down when i turn it on
Denon receiver has a common problem, keep shuting down after power button press, then red light blind. mostly, if none of amplifier output transistors blown, it must be IC7815 or IC7915 mulfunction, find it, replace it. then job down
Mar 16, 2011 | Denon AVR-1601 Receiver
I have an AVR 988 system that will only shut down manually. I have shut down the system, changed batteries in my remote. Neither solved the problem. Any ideas?
Its a common problem with this Denon model series 1508,1708,988 the trouble lies with the power supply voltage going low. Usually its either the 15 or -15 volt that goes low. If either voltage goes low it will trigger the protection circuit hence the unit will shut down.
Aug 09, 2010 | Denon Audio Players & Recorders
Problem denon avr 1910
most electrical units have a fuse inside,try taking cover off and checking for blown fuse,or,take it to radio repair shop.My Harmon Kardon stopped after 3 years,and the report said the unit that failed was quite a common problem for the modern multi channel amps,quite cheap to fix..All my tips are free
Jul 04, 2010 | Denon AVR-1908
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
I reset the microprocessor that my denon avr-886 , but is not working
One or the output channels is probably bad you can check for a short on the output transistors using an ohm meter. Make sure that the receiver is un-pluged. The ouput transistors will be on a large heat sink.
Feb 01, 2009 | Denon AVR-886 Receiver
Denon AVR 886 only shows analog input
Are your speakers able to handle the 886's power. I have the same reciever and changed by speakers as the Denon would turn off instead of frying the speakers.
As for the digital, have you used the option to change your audio feed and video feed. (for example - I'll show photos through the front input but use the CD -digital for music. Maybe the audio feed is locked onto an analog input. Just a suggestion.
Jan 01, 2009 | Denon AVR-886 Receiver
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Denon avr-886 VERY FRUSTRATED
Read the manual. You've either got crossed speaker wires, it's overheating, or it's a more serious problem. The same just started happening to mine, so I'm taking it in.
Oct 03, 2007 | Denon AVR-886 Receiver
680 people viewed this question
 Grubhead
Grubhead
