Question about Husqvarna Huskylock Computerized 936
Hi, I have Huskylock 936 serger, I set it up to sew 3 thread overlock, now it will not sew, it beeps at me. I have tried threading it 4 different times but it will not sew. The presser foot is down and the lower door is closed. Don't know what to do!!! Lorettas
  • 371 Answers
SOURCE: I need to know how to thread my Viking Husqvarna
You have a great machine. These are hard to thread but once you have mastered it, you'll have many years of great use. The owner's manual has instructions, as well as the inside door of the machine (the door that folds down on the front bottom part of the machine. However, you might want to follow-up with your local authorized Husqvarna Viking dealer. Most are eager to help you even if you didn't purchase the machine from them. Some even have classes on using the serger. You might try several stores in the area. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
One fundamental tip is to follow the color coding, start with green, then blue/navy, then red, and finally yellow. The sequence is work inside to outside with threading (green - blue - red - yellow). Do not try different order--especially with green and blue -- since the threads build on each other. I have switched yellow and red with no impact but green then blue is always the proper order.
Good luck.
Posted on Feb 11, 2010
  • 1116 Answers
SOURCE: trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Posted on Feb 21, 2010
  • 1116 Answers
SOURCE: instructions for threading the huskylock 34d overlock machine
I found this manual - http://www.sewingmachinemanual.net/
However, if you google 'how to thread a serger indi" you will get a video that will give you the basics.
Before you start, raise the antenna to it's highest position and open the tensions by setting to zero, or if your serger has auto tension, raise the presser foot to open the tensions.
Posted on Mar 21, 2010
SOURCE: I have a 936 Huskyloc Serger and have no
http://www.youtube.com/watch?v=NMQviHH1g4k
Posted on Jun 01, 2010
sewinsnap
  • 135 Answers
SOURCE: I have a Huskylock 234D serger sewing machine, but
At this point something is bent and you need to take it to the dealer
Posted on Aug 11, 2010
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Tension settings on empisal overlocker 754d, pulse ?
The standard tension for a 3 or 4 thread overlock is to set each tension dial at the midway point and then tweak it from there. It helps to use different colors of thread so you can distinguish what each thread is doing.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Perfecting Serger Overlocker Tension
Mar 13, 2017 | Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
How to Adjust Thread Tension on an Overlocker Singer Australia
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
936 Huskylock needle bar does not move up and down.
First, make sure the machine is engaged to sew. some machines,
have a knob inside the flywheel on the left side that disconnect the sewing mechanism to wind a bobbin without the needle bar moving.
Cheers,
Embroidery Services
San Diego, CA
Jun 15, 2016 | Sewing Machines
Huskylock 936 will not form a 4-thread overlock stitch
It may be difficult to solve a computer controlled machine with as many options as the 936 serger. Stepper motors control many of the functions. You can check out this video I made 4 years ago to get an idea of where to look.
Nov 19, 2013 | Husqvarna Huskylock Computerized 936
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
Huskylock 936 coverstitch will not form stitches
I just went thru the EXACT same thing, pulled up YouTube videos and discovered it was all about (1) how the LOOPER was threaded (the video taught me it is called "the puppy dogs head/ears" and that to thread it you follow the path of the ORANGE DOT (which often is combined with either blue/black, but just look for the ORANGE dot path no matter what the other color is with it) and that thread goes: "Around the puppy dog's neck and behind his ears". Honest to God this was part of my problem. (2) TENSION settings: I also discovered that even though the 936 has the adviser has all recommended settings for the stitches, you still NEED to tinker with the tensions. Specifically, I was set up for the WIDE COVERSTITCH to hem a knit skirt. I selected the KNIT MEDIUM (Auto M4) stitch and used these tensions: A needle 4, E needle 6, Looper was ok at 3. It worked like a charm and FINALLY I can do the stitch! Seriously, there are many YouTube videos (many lousy quality) that actually show and explain this stitch and how to set up your machine. Hope this helps!!! Good luck and happy sewing!
Feb 25, 2012 | Husqvarna Huskylock Computerized 936
I have a Huskylock 936 Serger and used it last week, no problem. I changed the threads for a new product and one thread came out and had to rethread. I know you have to thread the upper looper first then...
Recommend you remove all the threads and rethread from the beginning. ALWAYS RAISE THE PRESSER FOOT when threading and thread the upper looper first, the lower looper second. Sergers sometimes are temperamental about threading. When in doubt, start over from the beginning.
Jun 14, 2017 | Husqvarna Huskylock Computerized 936
Trouble with my Huskylock 680D overlocker Tensions
Feb 21, 2010 | Husqvarna Sewing Machines
Sewing Machines Logo
251 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
