Question about Apple Computers & Internet
Macbook adapter charger - Apple Computers & Internet
  • chidigathung
    chidigathung Feb 25, 2012
    How to repair frayed cable on old adapter?
    How to prevent fraying on new replacement adapter?
    Sergeant:
  • 314 Answers
Apple is replacing these even if out of warranty. Take it to a Apple store and have them look at it.
Posted on Feb 27, 2012
My macbook pro won't charge, why is the charger not working
make sure that the connection between the charger and macbook is clean.
If the charger lights up green and doesn't change to orange, then it may not be connecting. If it stays green, the battery might be dead or improperly inserted. It may need a different sized cord -- check for proper wattage.
Apr 30, 2014 | Apple MacBook Pro Notebook
Charger shortage
Try and borrow a charger from someone and see if that works, or even use your charger on someone elses macbook. Then you can work out if it's the charger that's faulty which will mean buying a new one or if it's the laptop that's faulty. What you want to do if it's the latter is entirely up to you.
Nov 27, 2013 | Apple MacBook Pro Laptop Computer with...
Macbook adapter A1184 stopped charging
Things break. Get a replacement on ebay. eBayeBay
Jul 28, 2012 | Apple MacBook Pro Notebook
Hi i have a macpro 13" not turn on ,the pwr adapter light its dim, i replace the adapter and continue not turn on . its not a new mac and was working few hour ago
If the power supply is dim it indicates a motherboard problem and is loading the charger down. The only option is to have a computer tech who is familiar with Apple Notebooks to check it out with an estimate.
Jan 07, 2011 | Apple MacBook Pro Laptop Computer with...
The fan on my macbook has turned on and the battery icon shows an X when it appears. Also when the charger is plugged in the light is a very dim green.
The green light on your power adapter is normal, this indicates that it is charging the battery. The fan within the MacBook is controlled by an internal heat sensor. The fan inside will speed up and slow down based on the internal temperatures.
The X icon for where the battery is, indicates that the battery is not connected or the system doesn't recognize the battery anymore. Meaning, you will need to buy a new battery for your computer.
Nov 14, 2010 | Apple MacBook Pro Notebook
Will a 60 watt mag safe ac adapter used w/ an A1212 17" Macbook Pro (normally uses an 85 watt adapter) harm either the adapter or the Macbook? thanks
Yes, I have used it this way.
It takes MUCH longer to charge the battery, especially if you are working on the machine with hard drive and cd drive spinning etc.
Also, if you run the battery out, it can take several minutes to get the machine back running after you reconnect the charger.
It was quite a relief to finally get an 85W charger, but your 60W will work fine.
Jul 01, 2010 | Apple Computers & Internet
My MacBook wont charge
So does the organge light still not come on now? If it doesn't try a different charger first. If that fails, your DC-Jack module or logic board may need to be replaced. There are detailed instructions on how to do the restore online. Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jun 19, 2010 | Apple iBook Mac Notebook
How do i know if its my battery thats not working or is my universal adapter not strong enough to charge it ?
- Your laptop should have an indicator that tells you that its battery is being charged (when plug-in to charger) or discharged (when running of battery).
- The universal adapter will have several voltage settings: make sure you have selected the correct voltage (DO NOT USE VOLTAGE SETTING HIGHER THAN REQUIRED OR YOU WILL DESTROY YOUR BATTERY REGULATOR!)
Dec 29, 2009 | Office Equipment & Supplies
Compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
Oct 04, 2008 | Xerox XG-91D 19" LCD Monitor
Can i install adapter to a macbook
You cannot install this adapter on your Macbook , it is only made to work with Windows operating system from windows 98se up to windows Vista, you can try to look for a airport adapter that will surely work with your Macbook...You can check this link for the complete details about this adapter http://cnet.nytimes.com/adapters-nics/netgear-wg111-usb-adapter/4507-3380_7-30791890.html
Hope that helps..............
Oct 03, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Computers & Internet Logo
35 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
