Question about HP LaserJet 1200 Printer
Paper jam I changed the cartridge and ever since then my paper keeps jamming. Even though it's jamming, I'm not seeing a warning light. Does this problem have to do with my printer or my computer? I have an HP 1200. Help!
  • HP Master
  • 1,879 Answers
Feed a paper and observe which side is grabbing the paper first. Cleaning the roller that grabs the paper helps.
If the jam happens inside, again observe where and inspect closer. Small obstructions can jam the paper since the clearance is very small because the printer is designed to feed one sheet at a time.
When rollers fail, it needs replacement and is usually done at a service center.
Posted on Oct 28, 2008
    Guru:
  • 859 Answers
To answer your question. It would have more to do with your printer, specifically one side of a roller bar slowing down more so than the other side. This could be caused by several things, the most common a foreign object in your printer slowing down or snagging the roller bar and mimicking a paper jam.
Since you just changed out one item, the problem would be associated with your most recent actions. I would look for and carefully attempt to remove any foreign objects from the insides of your printer.
At HP.com you will be able to enter your printer model and find pages on how to clean your printer. Doing this will inevitably resolve your problem.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Oct 28, 2008
    Cleaning your printer is recommended on a regular basis as it is. So, doing this simple but messy task, note that this is messy because of toner dust, will resolve your problem. I advise doing this outside and have two cans of air. As one can get very cold to the touch, you loose velocity, switch to the other can at this time. Then you can go back to the other can and so forth. Realize, that we working professionals have a special vacuum cleaner to assist in this task.
    Ask for help if you feel you need more assistance.
    Worldvet
  • HP Master
  • 13,433 Answers
Make sure you don't have too much paper inserted, make sure its a little loose, if you push it too thighly it wont come out correctly.
Let me get you instructions for clearing that jam in a moment.
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Printer suddenly stopped printing - alarm light is on continually, even though I pressed resume button - also sounds as if it is trying to send paper through printer.
Turn off the printer for about 5 mins then turn it back on. Can you provide the model number of your printer as well as any error codes on the screen if you see any.
Aug 27, 2008 | Office Equipment & Supplies
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Jam
alternative :
Oct 28, 2008 | HP 920 Plain Paper Fax
Paper keeps jamming even after clearing the path etc.
try this
alternative :
Oct 09, 2008 | Epson Stylus C120 Color Printer InkJet
Paper jamming
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Sep 05, 2008 | HP PhotoSmart 7760 InkJet Printer
Paper Jam feeder
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP LaserJet 1200 Printer Logo
131 people viewed this question
Ben Johnson
