Light indicates that the battery is charged but it won't turn on
SOURCE: I have a acer aspire
click on the start button, click on programs, and click on acer clear eye,,,,I am using this same puter right now
SOURCE: acer aspire 7741Z-5731 won't boot
Corrupted windows installation. If you can boot to safe mode, run a disc check and see if that resolves the issue, If it does not, or you cannot access it in safe mode, you need to repair your version of windows with the install disc.
Testimonial: "Very quick and helpful information"
SOURCE: Acer Aspire One won't turn
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
SOURCE: My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
