Question about Pool & Spa
Zodiac LM3-24 Battery Backup
Can the rechargable battery be replaced, it's got tags and would need to snap the battery off.. it should be right to replace the battery as long as the battery is in place properly.
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
robotek
  • 1512 Answers
SOURCE: Battery needs replacement
Hi alvaring
Use a med/thin guitar pick and slip it under the edge of the casings and run it around the perimeter to snap open the casing locks. This method works for all snap together devices, and I have not found a better way yet!! Good luck. A FixYa rating would be great for this bit of knowhow..
regards
Graeme
Posted on Mar 08, 2008
Tyranny
  • 21 Answers
SOURCE: the phone is not recognizing the backup battery. can someone please help me on how to charge or replace the backup. battery
The backup battery is located inside the phone and canno be replaced by normal methods. the phone needs be disassembled and the battery are solded on the board.
the lifetime of these bateries are very high, maybe 5 or more years, and the charge occurs every time when you charge the phone.
Try to leave your phone charging for more than 3 hours, and if the battery dont charge, try a master reset on it.
If ater all, the battery dont charge, maybe you make some mistake or shorted some circuit. Take apart your phone again and re-check all the steps to reassembly.
Good luck
Posted on May 24, 2009
kaicooper
  • 8 Answers
SOURCE: back of watch won't snap back on
that is a common problem...
Posted on Jun 19, 2009
Cytherian
  • 124 Answers
SOURCE: need replacement battery for braun Model number 5000-type 5724
You can certainly go to shaveroutlet.com and pay $9.99 per cell, or go to a place like onlybatteries.com and pay $3.69 per cell with a higher mAh (2200 vs. 1650, which means a longer run time).
Keep in mind that if you're not skilled at soldering, you'll have to buy the batteries plus circuit board. This will end up costing you nearly $40. In that case, you're probably better off going with a new shaver (get a new old stock 8000 series shaver for around $50 on average, at "that auction site"). :-)
Posted on Oct 22, 2009
What is the backup battery?
The Rechargeable Personal Air Purifier - Hammacher ...
www.hammacher.com > ... > Air Quality
Hammacher SchlemmerThis is the rechargeable wearable air purifier that eliminates airborne germs from one's personal ... The Plane, Train, And Automobile Solar Backup Battery.
Air Purifier Hidden Color Camera with Built-In DVR covert ...
www.ebay.com > ... > Personal Security > Surveillance Cameras
eBayAir Purifier Hidden Color Camera with Built-In DVR covert video battery backup in Everything Else, Personal Security, Surveillance Cameras ' eBay.
Ionizer Power Bank Air Purifier Fresh Cleaner External ...
www.ebay.co.uk > ... > Chargers & Docks
eBay
Jan 05, 2016 | Air Purifiers
Philips rq1260 can't be charged
If the lights come on when placed in its charger stand, it's most likely needs Needs a new battery, They require replacing after 3-4 years. Its a LC14500 tagged. Would only replace this if your experienced dismantling electronics goods. The battery requires soldering in by the tabs, and you need to keep the rubber seal intact and undamaged to maintain your waterproof seal.
Around $15.00 for a battery.
http://shaveroutlet.com/norelco-philips-8100-series-liion-battery-cell-p-753.html
Mar 22, 2013 | Philips RQ1150 SensoTouch Rechargeable...
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
I have a franklin sa-309 and I do not now how to remove the red tag on the right side.
The red tag is most likely the end of a cloth strap used to help the user remove the (2) AAA batteries
from the Franklin SA309 Spelling Ace Pro & Puzzle Solver. To store the red tag back inside the
uit, you'll need a #1 phillips screwdriver (the "regular" size phillips screwdriver is a #2, so the #1 is
a bit smaller).
To access the batery compartment, turn the unit over, and unscrew the screw holding the
battery compartment closed. Then push the red tag inside (flattened to the batteries), and
re-install the battery cover screw.
Here's the 24-page online users manual for your device (PDF file):
http://www.franklin.com/manuals/sa-309.pdf
Consult pages 4-5 for battery replacement.
May 29, 2011 | Computers & Internet
Lens doesnt close when switching of the camera bought it today!!!!!!
If lens won't go back, Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
--- Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
If this will not solve the problem your device need service (repair)
Good Luck & have a nice day
Rating the solution in highly appreciated.
Aug 18, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Error 161 & 163 on ibm aptiva 2168-m62
try this one:
Errors 161, 192, 163.
All three of these errors are connected to the back up
battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips
screwdriver required)
2. find the small connector with 1 black & 1 red wire
coming from it.
3. disconnect above connector and gently pull the
Red&black wires. The backup battery should just pull out
from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the
packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot
welded so need to be cut/broken off). Buy a new CR2025
battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
(see the one just removed). Solder the leads onto the new
battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all
exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows
161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off
switch at side.
Mar 05, 2010 | Computers & Internet
Lens won't go back in
  • Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
Rating the solution in highly appreciated....Good Luck
Feb 28, 2010 | Canon PowerShot A470 Digital Camera
Less back up time
I found the following on APC's web-site for the APC Back-UPS, this will hopefully fix the problem:
You can also perform a manual runtime calibration. This could be done if you have changed your equipment load or battery. Stop the PowerChute software from running; disconnect the serial cable between the computer and UPS. Next unplug the UPS from the wall and let it run on battery until it reaches low battery. Once it reaches low battery plug it back into the wall outlet and let it recharge. Recharge time can take up to 4 hours.
from link: http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=2819&p_created=1048797826&p_sid=tANR-rxj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yZWNhbGlicmF0ZQ**&p_li=&p_topview=1
Mar 31, 2009 | APC Back-UPS RS 800VA UPS System
Coin cell backup battery
No the coin cell backup battery is not rechargeable. If the MobilePro 900 back up battery is low it should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the “MobilePro 900 Handheld PC’s User’s Guide” for detailed replacement instructions.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Pool & Spa Logo
300 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
