Looking for solve problem : my volume level from 1 to 4 only and stuck on that level (level 4) normally should be until level 100.
SOURCE: LG Volume to 100 by Itself - will NOT respond to remote
It's hard to diagnose without a model, but, given the problem I would say it is a 42LC7.
If it is, then, it needs a modification in the main PCB. We used to jumper coils at first, now we have to change the main PCB.
It's less than a year old, it's under warranty.
For a servicer in your area that makes house calls:
Contact LG at:
(800) 243-0000
If you have any questions, reply to this post and I will respond.
SOURCE: USER'S MANUAL FOR 42LA45H LCD COLOR TV
I need to find a manual for the remote so I can figure out how to use the remote
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
