Question about iLO DVDR05 DVD Recorder
Records ok but after resetting, I don't have audio
After resetting to try to override password which my child set accidently, I have no audio when recording dvd's. what did I do? -still can't get around password either
My manual says that the MASTER passwordis 1369. You might try resetting the password using this in the current box. I have read of others having trouble with the audio. check and see if other settings got changed. pg 25 of manual says have disc in unit, access the setup menu and try the user default. Also supposed to be a help section in the setup menu. Hope this helps.
Posted on Oct 29, 2008
DVD disc is stuck in Panasonic DMR-XW300 DVD recorder but somehow child lock is showing. Cannot unlock child lock!
Try pressing and holding the OK (the center button in the arrow key section) and Return (on the lower right of the arrow keys) buttons on the remote control at the same time. You should see the X LOCK message disappear. (Holding these two buttons will toggle the lock on when it is off.) This is shown on page 89 of the manual which is available from Panasonic on the product site: http://www.panasonic.com/au/support/manual-download/players-recorders/video-recorders/dmr-xw300.html . The direct link to the manual is http://www.panasonic.com/content/dam/Panasonic/support_manual/DVD_Recorder/English/rqt9135-l.pdf .
If you are using a universal remote, the code currently in use may not match this feature. Try the original remote if you can. A replacement remote that should match all of the features is here: http://www.tvremotes.com.au/panasonic-remotes/original-panasonic-remote-control-n2qayb000273-dmrxw300gl .
I hope this helps.
Jan 15, 2017 | Panasonic Televison & Video
Pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
My child has set a password on the Luxor smart tv and now I can't watch tv as they have forgotten the password , is there anyway of resetting the to with the password
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Nov 30, 2016 | Luxor Televison & Video
How to unlock sharp Xflat 21TK21 series tv, my child accidently lock it............... plz help
my schreen tv id look .
key _ _ _ .
and I didn't model .
put thes model is 20 inch.
place help my .
Mar 27, 2015 | Sharp Televison & Video
My child lock is on on my phillips 755vr dvd player how do i turn it off without the remote
Basically, the child lock feature is a security feature to keep the children away from unauthorized video content.
Your best bet is to get an original replacement remote.
You may try this general step to unlock without the Remote. However, it may not work for all the models.
Please hold down the Power button on the Player until "CHILD LOCK" or the "Key symbol" disappears from the front panel display. The Player will be unlocked.
If you had set a code number - the override code should be able to resolve the issue. Please follow the below steps to enter the override code.
1. Press SYSTEM MENU to display the Setup menu.
2. Use the Number buttons to enter the 6-digit number
"210499". The previous password will be cleared.
Hope this helps you in resolving the issue.
Thank You,
Ravi Yelde
Aug 18, 2014 | Televison & Video
F10 function key has password i didn't set ?
Since this came to me as a desktop question I will give you that set of instructions. you will need to power off the machine and unplug it. Remove the side panel of the computer (or top panel depending on the model). When you look at the motherboard you will see a CR2032 battery that powers the BIOS chip to allow it to retain it's settings such as password, date, and time. There may also be a jumper on the board (a little plastic square with copper in it) to reset the BIOS. You will be looking in the same general area of the battery for this jumper and it should be labeled CMOS or Reset.
If the jumper is present you will need to use it to reset the BIOS. If using the jumper doesn't reset the password then you will need to remove the Battery I previously mentioned and let the computer sit without power or battery for several minutes.
If this still does not remove your password (or if you would like to try this first) you can try to use a manufacturer override password. On a Compaq system the override should be Compaq. That does have a capitals C and the password is case sensitive.
Best of luck!
Nov 13, 2011 | Compaq Computers & Internet
My Canon PowerShot not recording audio
Try to reset the camera to default settings.... go to the menu and look for the reset default on the menu...that should override any accidental settings or mutings and get you back if the microphone is still functioning..
K
Aug 05, 2009 | Canon Cameras
DOLBY DIGITAL
change seting to digital ok muti control noob spin itto u see dolby digital when ina movie ok not anlog others use a speakers only on front k not a and b a only and cheak dvd players out put setting audio in main dvd menu set itto bitstream out not pcm ok sound awsome hit thx button on front turn on auto but spin that dial in front to u see digital on it ok when moving going on screen set audio track in dvd to 5,1 ok not 2 ch
Dec 21, 2007 | Kenwood KRF-V5060D Receiver
iLO DVDR05 DVD Recorder Logo
59 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
