Question about Sharp R-9H84B Microwave Oven
Popcorn I can not figure out how to pop popcorn in my Sharp R-9H84B? Please Help!!
  • Sharp Master
  • 9,086 Answers
According to the owner's manual (which you can download free from us here),
1. Place the bag of popcorn over an upside-down 9" glass (or paper) plate.
2. Touch POPCORN pad.
It will cook and stop automatically.
If this does not work, you may have a bad humidity sensor or control board, etc. and parts for this model are generally no longer available.
Posted on Nov 08, 2008
Sharp microwave makes roaring noise light go on and off when i popped popcorn in bag help
Is it a loud growling noise and it doesn't cook? If so, it's probably a shorted high voltage diode. Secondly, it may be the magnetron. I don't think the popcorn had anything to do with this failure.
Oct 18, 2013 | Microwave Ovens
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Need part # for magnetron for sharp model R-9H84B. also supplier.
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 17, 2011 | Sharp R-9H84B Microwave Oven
Sharp Microwave/Convection vintage 1994, model # 9H84B turntable has suddenly stopped turning. When functioning, table could start rotation in either direction.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 07, 2010 | Sharp Microwave Ovens
We have a sharp r-9h84b convection microwave and the carosel has stopped working when the tray is in place. Any thoughts the carrosel seems to rotate very slowly when there is nothing on it.
It's almost certainly a bad turntable motor.
The part number was RMOTDA079WRE0 but it is listed as no longer available.
In some cases, older microwaves are available locally at repair shops or on Craig's List.
If you want to keep your eyes open, this same motor was used in the following Sharp models:
R9A20
R9A50
R9H11
R9H60
R9H66
R9H71
R9H73
R9H76
R9H80
R9H81
R9H81B
R9H83
R9H84
R9H84B
R9H91
R9H91B
R9H93
R9H94
R9H94B
Good luck.
May 23, 2010 | Sharp R-9H84B Microwave Oven
Not heating food but will heat plate. wont pop popcorn. takes three times as long to heat food even if on a paper plate
heatman101
Mar 04, 2010 | Sharp R-55TS Microwave Oven
Sharp R-9H84B Microwave Oven was working normally
There should be an oven thermal cutout (part # RTHM-A048WRE0) on top of the oven chassis / cooking cavity. It will be on the left side top.
Also, there is a 150 degrees C magnetron temperature fuse (part # QFS-TA013WRE0) mounted on the side of the magnetron.
Lastly, there is a line fuse, probably located on the door switch mount between the switches.
All of these should read "closed" or virtually zero ohms.
The fuse and magnetron temperature fuse may be available at local appliance parts stores, but you can order parts from Encompass here or you can call them toll-free at 866-779-5835.
The part numbers above end in zero, not "oh".
Let me know if you need more help. Otherwise...
Aug 08, 2009 | Sharp R-9H84B Microwave Oven
Heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | Sharp R-820B Convection/Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Microwave Ovens Logo
218 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
