Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
No picture. When I plug television in and turn on,the power button lights up but there is no picture. I have back panel off and none of the three projection lenses have any color. Slight humming from rear of set. Thanks for any help on this matter.
  • john bires Sep 03, 2006
    Thought I might add, the humming noise seems to be coming from what looks to be a (primary coil) that has a sparkplug type wire leading to a (secondary coil) that has Three sparkplug type wires leading to each individual projection lens. Thanks again for any and all help.
    Thanks for replying to my questions. Going to give it a shot, as right now can't really afford repairman prices. Thanks Again
    President:
  • 3,130 Answers
Sounds like a short in the hirizontal output section of the set. Please this is a high voltage circuit and not some place a non trained tech should be poking about. Find a service tech to assist you with this repair.
Posted on Sep 03, 2006
SOURCE:
Sound but no picture. I'm thinking I need a new picture tube but how much is it going to cost me?
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Jan 30, 2010 | RCA P52936 52" Rear Projection Television
Flashing power button no picture or sound!!!
Ive had this problem... Usually all that is needed to be done is a few reboots... First unplug and let sit for one min and then plug in and allow three mins for it to boot... Didnt work retry and retry
Dec 31, 2009 | Philips 60P8342 60" Rear Projection...
The power light flashes 3 times the pauses, then three times again. No Picture. If I unplug the power and plug it back in then hit the power button it acts like it trys to come on then pops off and fashes...
Thats the error code for Convergence shutdown. You can get the PT53WX53 convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with instructions.
Nov 25, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
My mitsubishi 65087 remote stopped working and none of the buttons on the front control panel would work either, including the power button. Couldn't turn set off, so unplugged. When plugged back in, green...
ws65087 or what?
Most of these sets have a self check feature--when power light goes off press and hold both the Menu and Input buttons for 5 seconds and release both--power light should blink a two digit code--like,,,,,,,,2 blinks a pause and 2 blinks---CONFIRM EXACT MODEL NUMBER AND ERROR CODE FOR ME.
Allow for time difference--I am in California.
sd tech
Oct 12, 2009 | Televison & Video
Shows some sines of power but dosn't turn on.
U MUST HEAT IT UP BEFORE IT WILL TURN COMPLETELY ON U HAVE TO HEAT UP THE CURICIT BOARD AND THE BACK OF THE T.V. BEST WAY TO DO SO IS USE A HAIR DRYER AND TAKE OF THE PANEL IT WILL WORK FASTER.
Jun 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips Rear Projection No Picture
check power supply and fuses.
May 31, 2009 | Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
TRY UNPLUGGING THE SET FROM THE WALL FOR 2 MINUTES THIS WILL ACTIVATE THE AUTO RESET WHEN YOU PLUG THE SET BACK IN.
Dec 28, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
