Question about Sager NP9890 Notebook
How do I find out what motherboard is in my Sager NP2096. I am not able to run Belarc because my computer won't turn on. Any help would be appreciated
How do you know what bios you areusing on your computer?
The BIOS is in a chip on your motherboard. When you first turn on your computer, hitting the Del, F2 or F12 keys (depending on manufacturer) will usually get you into your BIOS setup. You may find the name and version of the BIOS there.
Also consider downloading and running the Belarc Advisor on a working computer... The Belarc Advisor produces an extensive analysis of your system and sometimes shows specific motherboard and BIOS information.
Belarc System Management For The Internet Age Software license management...
Sep 25, 2017 | Computers & Internet
What computers have a d946gz15 motherboard ?
If the case doesn't have any id or logo, you may have a "home build". You can download and run the free Belarc (http://www.belarc.com/) to get more info on your computer.
Jul 29, 2014 | Dell Computers & Internet
Sager laptop freezes up on startup. Help!
Define lock up. How far does it get into booting? what operating system? Any errors? What was the last things that you installed?
Jan 05, 2013 | Sager Computers & Internet
I'm looking for a Sager 5600D motherboard replacement. Please email me at mailtorob@yahoo.com if you have this part for sale. If I can't get the motherboard I would consider selling my Sager....
Sager and Clevo are one and the same. The issue is Sager has no spare part inventory. This is a market strategy. You can send it in for repairs but they charge a lot of money. Sounds like the issue would be solved with a reflow and it is a common problem with the model you listed .
Nov 27, 2017 | Sager NP-5620-C Notebook
I have a problem with my computer. after i reinstall windows xp, I do not have drivers for the motherboard. I was confused because the motherboard had no clue the manufacturer. listed in the motherboard...
If you can't identify the motherboard, download Belarc Advisor from here:
http://www.belarc.com/free_download.html
Save it to the Desktop, then install it and run it. Belarc should be able to tell you exactly which motherboard you have. Post that information here and then maybe someone can help you find the drivers you need.
Good luck; let us know the information from Belarc and someone should be able to help you solve this problem
Apr 25, 2011 | Intel Pentium 4 505J Prescott 533MHz...
Hi , when i open device manager ( after formatting) i see 2 marks in yellow color : sm bus controller video controller ( vga compatible) . notice : the computer is Pc and the windows is xp
Your graphics adapter's (VGA card) drivers are missing. that's why you are getting this problem. You would have trouble playing games and using other 3d applications in this state.
If your graphics adapter came with a disc, insert it and follow the instructions to fix this problem.
in addition you can try these:
Since you haven't mentioned the adapter's make and model, I can't provide an exact solution, but if you go to the graphics adapter's website, you might be able to find the drivers. You might also be able to find the drivers on www.drivermax.com. Good luck.
Apr 25, 2011 | Computers & Internet
USB ports dont do anything when I insert a USB key. I think its because of the Device Manager missing some devices. I check and I use to have lots of devices under the Universal Serial Bus Controller but...
Hi gracie,
I suspect that your motherboard chipset drivers have become corrupted; that would cause the USB problems you've described. What motherboard does your system use? If you can't identify it, simply download Belarc Advisor from here:
Save Belarc Advisor to the Desktop; when the download is complete, double-click the file ("advisor.exe") and run it. Belarc should be able to tell you which motherboard you have. Post the make and model of the motherboard here and then maybe someone can help you find the motherboard chipset drivers you need. Once you reinstall the chipset drivers, your USB problems should be solved.
Run Belarc and post the information about your motherboard. Also, don't forget to reboot your system after you reinstall the chipset drivers. You MUST reboot to get the USB drivers to load at bootup, which should solve your problems.
Apr 24, 2011 | Computers & Internet
What motherboard does the sager 888e have
go to www.belarc.com and download adviser.exe. Run it, it will tell you a lot about your computer.
Nov 04, 2009 | Computers & Internet
Need to replace the motherboard on my computer and need to know what motherboard to order
what kind of computer do you have, who made it, if it hp, or dell or a factory made like them, you need their part number, go their web site. If not, go to this link and install then run belarc advisor, it will tell you make and model of your motherboard
Jun 20, 2009 | Dell Computers & Internet
Laptop wont start up/POST
if even bios doesn't boot up...den its the motherboard problem..since its just few months old system it should b under warrenty...
May 22, 2009 | Sager NP-5620-S Notebook
Open Questions:
Sager NP9890 Notebook Logo
Top Sager Computers & Internet Experts
David Payne
David Payne
Are you a Sager Computer and Internet Expert? Answer questions, earn points and help others
