Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
Master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
Already replaced stack flue sensor, thermistor, and igniter on my 4 year old Mastertemp 400 heater. Still get the same result...kicks on, ignites, heats for about 15 seconds then shuts off and display says E05. Any suggestions that don't involve calling out my pool tech for a $175 service call?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Eo5 is exaust temperature if exhast gets above 475 degrees it will shut down the heater. check inside combustion chamber for evidence of rodents they build a nest down in the fire cone and around he heat exchanger this will cause high temos and set the eo5 code.
you can depress pool on and spa on for 10 seconds and display will read the exhaust temp , if it get itno the high 400,s you have a problem in there and must be taken apart and inspected
Posted on Jun 24, 2014
  • 4 Answers
I have the same exact problem with this unit. Obviously getting gas to the unit, because it runs and pumps out some serious heat for a short time, but then kicks off. Did anyone ever figure this out or did you buy a new heater? :-)
Posted on Aug 01, 2012
I have had the same problem with my '400' since it was new. I contacted the manufacturer and got the run around. I have been trying to get this resolved and now, a year and a half later, have decided to buy a different heater. Anyone want to buy a hardly used Pentair 400? sandtrap699@yahoo.com
Posted on Sep 23, 2013
  • Scott Corey-reid Apr 16, 2014
    check the heat exchanger it its calcified. inspect thermal regulator and internal bypass
5 Suggested Answers
  • 94 Answers
SOURCE: Pentair mastertemp 200 will work for a while and
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix. with inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable.
Posted on Feb 25, 2011
SOURCE: getting a E05 code on my Mastertemp pentair
I have same problem. Mechanic not sure what to do. May need a new board.
Posted on Jul 31, 2010
  • 990 Answers
SOURCE: I have a Pentair Mastertemp 250 pool heater with
This is an ignition flame falure code. Could be you don't have gas getting to the pilot, no spark to ignite the pilot or your ignition is not reading the flame. Sorry to say but it's probally time to get the pool guy out to look at it. Good luck.
Posted on Apr 15, 2010
john224
  • 1378 Answers
SOURCE: Have a Pentair MasterTemp 400
Thank you for posting your question here on Fixya.com.
Error code E05 can be caused by many failures in several places. The owner's manual has a decent flow chart in it to help diagnose where the trouble lies. You will find it on page 43 here...
http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Identifying problems with an electronically controlled pool heater is not a job for most homeowners without training and/or experience with this type of equipment. If you are unsure how to proceed no amount of tips from a site like this will replace experience. You may want to consider hiring a professional to look at your heater.
If you decide to pursue the repairs and need additional support please post as specific a question as you can as a comment to this reply.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on Mar 30, 2011
How to bypass stack flue sensor?
if the flue sensor got hot and went out heater is running too hot is your gas pressure correct if not you will soot up the heat exchange and burn up the heater also see if you have the correct size gas line that could do it also you must have a dedicated line from the gas meter
Sep 01, 2014 | Pentair 460732 MasterTemp Heater 250BTU ...
Keep getting error code E05 When trying to heat the spa
eo5 is the biggest pain for pentair heaters. it can be caused by several things. stack flue sensor, wiring harness from stack sensor back to circuit board, thermal regulator, flame sensor, etc.......
Nov 30, 2013 | Pool & Spa
Replaced flue stack sensor still have code e05 starite sr400lp
ignition turn off reset unit check safety circuit then gas pressure if overheated if ok check for cobwebs if burn tubes possible fenwal overheated if no voltage to ignitor
Mar 09, 2013 | Sta Rite Maxi Therm 400k Btu Propane...
Error e05
The EO5 error code on the Master Temp says that you have an "open stack flue switch or sensor. you may need to replace the sensor
try checking the vent
Oct 08, 2012 | Heating & Cooling
EO5 and Service Heater Light on Pentair Master Temp 400 Nat Gas
check gas pressure and supply if too low heater will soot up and overheat that's the flue sensor if gas ok check burn tubes for obstructions
Sep 02, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair pool heater error e05 begins to heat then shuts off heat
This issueis related to the stack flue sensor and it might have a wiring problem or a bad sensor. I recommend you call the Pentair technical support at 800-693-0971and they should be able to help you figure this issue out further. Ihope this helps.
Oct 08, 2011 | Pentair Mastertemp Pool & Spa Heater Dual...
Code E05
E05 and E06 is the error codes for a faulty stack flue sensor. try changing the sensor first is the cheapest. if that doesn't work check for corrosion on control board in which case will have to change out board.
Apr 20, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Value Stack Flue Sensor
3.5 to 4K If you want to bypass the sensor just jump a 1 dollar resistor in between the two wires. If you want to put another sensor just use a standard gas heater flute sensor(2dollars) and put in line with the resistor
Feb 07, 2009 | Sta Rite STA-RITE SENSOR,FLUE TEMP -...
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
1,922 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
