Question about Electrolux Microwave Ovens
How to replace door switch on e124m0451ba - Electrolux Microwave Ovens
My Kenmore Microwave Hood combination starts running as soon as the door is closed & continues to run until I unplug the unit. I replaced the door latch a few years ago. Any idea what's wrong?
Sounds like door switch problems, you say you replaced the door latch but did you replace the door switches too. most newer units have door switches with small 3/16 terminals and small undersized wires going to them so they get how and melt the plastic body of the switch and it causes a back feed of voltage when it is not supposed to be there. Check under the blades of the switch and see if you have any melted plastic of the switch body there, that will be your bad switch I recommend replacing with a switch with 1/4 terminal, they hold up to the current much better. Change the wires to the switch with larger ones that can handle the current better without getting hot
Jun 27, 2018 | Kenmore Microwave Ovens
How do you replace the door switch for the door in the microwave oven?
Take the cover off, the switches should be pretty easy to replace. In the several I've done, they just snap out, unplug, and then snap back in.
Oct 25, 2015 | In Microwave Ovens
My Magic Chef microwave tripped a breaker,I found a melted door switch and replaced it, the other three test ok.With the door closed everything works like new. When the door is opened the breaker blow
The only thing I can think of is check to make sure all switches are aligned correctly otherwise you will keep tripping the breaker, I'am certain that one of your switches are not properly in position.
Jul 07, 2012 | Magic Chef Microwave Ovens
I would like to fix a door switch on wolf MW24
The adjustment does not last, the technician should have replaced the door switch from the beginning to avoid a callback and leaving a bad impression. To trouble shoot you will need a digital meter, if you have one one post back.
Jun 28, 2012 | Sub-Zero MW24 Microwave Oven
Have a Panasonic Microwave NN-SA616W, when door is closed looks like touch pad works perfect, but when I open the door start to make a clicking sound and the light starts to function intermittently (like...
There are usually three interlock switches in the door mechanism. One is in the power circuit for the magnetron, one is in the relay drive circuit, and the third is a logic input to the controller. Many times the one in the relay drive circuit turns on the oven lamp when you open the door at the same time it disconnects the magnetron relay. If the lamp relay is stuttering irregularly, that door switch may be going bad.
Another possibility (if this happens only when you open the door while the oven is running) is that the magnetron power door switch is stuck in the on position. This is not a safe condition. Replace that door switch ASAP, and get in the habit of turning off the oven before opening the door.
May 31, 2011 | Panasonic Microwave Ovens
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
I think I have a bad door swtich on a frigidaire microwave
un plug the oven, un screw the screws and remove the cover, look behind the door where it closes and you will see a micro switch, and two wirers, note where the wires and screw is located and remove them. get a replacement switch NOTE!! make certain that it is the same type of switch ie. normaly open or nomaly closed. carry the switch you to get the replacement. replace the switch and the wires. if you want to verifry that the switch is defective you can have it tested when you go to the spares store to obtain the new one.
Jan 05, 2009 | Frigidaire FMV156D Microwave Oven
Microwave shuts off by itself
The microwave has a safety door switches (2-3 micro switches)
The door mechanism should hit these micro switches. If you can open the machine, you can see that these micro switch has a holder that you can adjust and tighten to make sure that the hook of the door should activate them.
Mar 30, 2017 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
