Question about LG 42LC2D 42 in. LCD HDTV
What is the code for a 42 - LG 42LC2D 42 in. LCD HDTV
  • LG Master
  • 1,214 Answers
The password in France is 1,2,3,4,
When you turned the tv on for the first timethe initial settingscreen came on and you probably followed the screen instruction to customize the tv settings.
I assume that by code you mean what we ordinary humans call password.
If this did not work out for you. You can access Factory Reset by accessingOPTION on the main menus.
good luck
kolbrun
Posted on Feb 25, 2012
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
Code 42
code 42 is related to EST ... look for the timing connector if plug if not bypass control won't activate and set 42
the pick coil ,ignition module defect ,
hope it helps
Mar 24, 2014 | 1987 Chevrolet R10
Xerox 1000 print engine fault codes 42-334 & 42-335
You can google this information or call customer service from xerox
Jan 11, 2014 | Office Equipment & Supplies
94 gmc safari 4.3 engine codes 42 and 67
DTC - 42 Ignition bypass circuit error
DTC - 67 AC system low on charge.
Oct 15, 2012 | Cars & Trucks
93BUICK H BODY 3.8, CODE 42, HELP!
On 3.8 engines I have seen problems with the cam and crank sensors - also the harmonic balancer and the magnet on the cam gear.
You might want to take a look at those issues too.
Aug 31, 2012 | 1993 Buick LeSabre
What are obd codes 41&42
41 and 42 are not valid codes for a 1999 Dodge of any model, these are OBD2 systems, the codes are OBD1 (89-95 models). OBD codes are in this format
PXXXX, the "X's" are numbers from 0-9
Dec 11, 2011 | 1999 Dodge Caravan
Rough idle, codes are 12 31 43 17 42 11 42 42
CODE 12 - BATTERY BEEN DISCONNECTED. CODE 31 - EVAP SOLENOID CIRCUIT. CODE 43 - IGNITION COIL 1 AND 3 PRIMARY CIRCUIT CODE 17 - ENGINE IS COLD TOO LONG REPLACE THERMOSTAT. CODE 42 - AUTO SHUTDOWN RELAY CONTROL CIRCUIT.PROBLEM COULD BE ASD RELAY OR YOU HAVE A SHORT IN THE WIRING TO THE ASD RELAY.
Jul 29, 2011 | 1997 Chrysler Town & Country
Getting codes 12 43 42 42 55 96 caravan 3.3liter
55 is the ending of every code so that isnt a trouble code either
Nov 04, 2009 | 1996 Dodge Caravan
1991 chevrolet silverado truck engine hesitates, fuel injected. Gives me codes #42 and #44
Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase ...
Code 42 : Electronic spark timing (EST) circuit fault
Feb 17, 2009 | 1999 Chevrolet Silverado 1500
Codes fail
Code 42 (I couldnt find what that converted to in normal ODB-II codes) is the code for an open or shorted circuit in the fuel pump relay circuit.
Code 55 just means end of codes. Code 55 just tells you it has reached the end of the report, so basically the only engine code you have is 42.
Jan 02, 2009 | 2006 Chrysler Neon
LG 42LC2D 42 in. LCD HDTV Logo
104 people viewed this question
Computer Repairing
Computer Repairing
