Question about GE XL1800 1100 Watts Microwave Oven
Odor When my microwave is turned on for more than 1-2 minutes a fishy odor comes out of the vents, what is this
  • GE Master
  • 9,086 Answers
It may be an overheating magnetron or high voltage transformer.
It should have filters. That would be covered in your owner's manual.
You can download GE owner's manuals and installation instructions here.
Posted on Oct 30, 2008
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Can the MMv5208w microwave oven be vented into the room? Or does it require outside venting?
    alot of these units can just be vented right out front grill of unt. outside would be alot better so that the odors are not being smelled indoors but the fan housing can actually been changed to blow up or you can make it blow out the front grill requireing no venting at all...hope this helps you out good luck
    Jan 05, 2011 | Maytag MMV5208W Microwave Oven
    Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
    Some interesting reading on page 8 of the owner's manual:
    "Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
    And on page 20:
    "If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
    "Using the Vent delay off button
    1. Press the Delay Off button once to turn the fan off after 1 minute.
    2. Press the Delay Off button twice to turn the fan off after 3 minutes.
    3. Press the Delay Off button three times to turn the fan off after 5 minutes.
    4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
    5. Press the Delay Off button five times to turn the fan off after 30 minutes."
    If for some reason you don't have your owner's manual, you can still download it free here.
    Jan 01, 2011 | Samsung Microwave Ovens
    Microwave runs for about 3 seconds and turns off
    most likely the thermistor that shuts off the magnetron tube for overheating is defective,if all else is good and there are no hot odors,its mounted on the vent side of the mag
    Jul 25, 2010 | Panasonic NN-S540 Microwave Oven
    My Whirlpool microwave hood combination was installed when I bought my home. I can hear the exhaust fan run when I turn it on but it does not pull any smoke, steam or odors from the stove top. I can put...
    sounds like they forgot to flip the vent louver,
    it sits atop the microwave and needs to be rotated to the proper direction for venting.....
    Oct 13, 2009 | Microwave Ovens
    Have a smell from cleaning solution I used to clean out microwave. Smell is still in microwave
    Baking soda is good at absorbing odor. Maybe you could sprinkle a generous amount on the bottom of the microwave and run it on defrost for about 30 minutes. If the odor seems to abate after this, repeat 'til you're happy.
    May 01, 2009 | Kenmore Microwave Ovens
    Fishy odor
    Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
    GE XL1800 1100 Watts Microwave Oven Logo
    59 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
