Question about Spectra SS250 DVD Player
Almost fixed the gears in the player moves properly and have no problem but when i go to stick a cd in it it gets almost all the way in then starts clicking looking at the inside while loading a cd i see the gears get stuck but cant figure out why they are fine something else is causing them to get stuck any cles?
    Top Expert:
  • Spectra Master
  • 48,698 Answers
Could be a weak drive motor or binding gears
Posted on Jan 14, 2018
2005 jeep grand cherokee 6 disc cd changer wont take disc cd door wont open
time to up grade
or go broke fixing old system.
retire it.
get a media head, and use USB flash mem stick.
DISCs are dead tech, (rip yours to MP3 and move on,, really)
or WAV if you are super HD audiofile.
Apr 08, 2015 | 2005 Jeep Grand Cherokee
CD PLAYER GEARS OUT OF SINC.
Hello
The disc loading mechanism should be realingned. It is a skilled work. It will be best to done it by any experecinced service technician, if you are not familier and expereinced with this work. On rare occations, one gear wheel may need replacement. OK.
Dec 26, 2011 | Audio Players & Recorders
I have an old Sony CD player (CDP-M47) - its probably about 20 years old (or so). The cd drawer has started sticking but with assistance if I can get a CD in it plays o.k. Is it fixable?
do you have to push it slightly for the drawer to go in?
if so then aply some wd40 or other lubricant to any gears or theeth on the drawer
and wd40 works fine with electronics
http://www.wd40.co.uk/index.cfm?articleid=1519
Jan 06, 2010 | Sony CDP-C265 CD Player
BMW CD Changer MP3 player is connected to power and i-bus in e39 (1999 BMW 528i). When I press the button on the display monitor to toggle between Tape and CD, most of the time the CD does not show up (it...
in the unit there are two things that you will have to check
1) one is the lens which reads the cd in the unit.
2) second is the gear that moves up and down to the tape/cd.
if the lens is not getting adjusted after you turn it on/off then this problem happens also if the gear is not moving properly then also same problem occurs.if the gears are getting blocked then also this happens.as you mentioned it works that means the unit is not faulty but there is minor problem in lens or gear assembly just get it resetted by checking it.also local electronic repair shop can realign the unit.the unit need proper servicing to get it work properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Car Audio & Video
My cd player makes a funny noise and does not play cd it keeps saying error and reset
take the cd player out of the dash. remove the metal casing from around the unit (load of small screws. Inside the cd mechanism, more to the side, there is a small gear...this can slip off the other gear that drives the cd. just push it back on. I then secured mine in place using a bit of tape...just be careful not to stick it to moving parts. works fine everytime now.
Oct 21, 2009 | Sony WX-C570R
CD player skips on early tracks
The lens assembly in a CD player glides along on a two rail track, kinda like a railroad track except tubular. The lens carriage is moved over this track by a small motor driving a worm gear. (Think long, tubular and spiral). If the rail tracks or the worm gear dry up or have dust accumulating on them, this could be the cause. Normally they have a light gear oil or lithium grease on them to keep them lubricated.
Mar 08, 2008 | Audio Players & Recorders
CD player damage
This can be a messy and frustrating problem to fix. You have to insure that the gears which control the opening and closing of the disc tray are correctly aligned with the apparatus inside. I have fixed this successfully on my own, but I must say it wasn't easy and involves removing the cover to give you better access, taking the tray out again and fiddling with it until everything is lined up properly. Might be worth sending for repairs.
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
Dvd recorder goodmans door sticking
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Sep 07, 2007 | Televison & Video
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
CD player not working
NO NO NO NO NO NO dont be sticking a screw driver where you dont know where its going!!!! Theres no belt under the turntable as its a direct drive motor. It the platter dosent turn then that means that the laser is not focusing on the disc. This could a combination of five differant things. First is a simple one as the lens may need cleaning. Try first by using a good lens cleaning disc. Second make sure the slider that the lens is attached to is all the way back to the platter as sometimes there is a small belt that drives the slider assy via a worm gear and that belt goes bad alot as the worm gear i've seen get gunked up with air and dirt. Third is the platter its self . It may have slipped down to close to the lens and it wont focus. Forth could be the motor drive curcuit is defective . Coulkd be a bad motor control ic or the b+ going to the curcuit. and finally but not least could be a bad laser assy. If this is bad you might as well buy a new unit unless you can install one your self but be warned if you do you will need to alighn the new PU assy for tracking and focus gains as well as rf azmuth and laser power. Good luck I hope this put a little lite on the subject for ya.
Apr 26, 2006 | Panasonic RX-D11 Cassette/CD Boombox
Spectra SS250 DVD Player Logo
Top Spectra Televison & Video Experts
mikemail1
Tom Chichester
Duarte Giron
Duarte Giron
Are you a Spectra Televison and Video Expert? Answer questions, earn points and help others
