Question about RICOH - PRINTERS Ricoh Aficio Sp C430dn - Printer - Color - Duplex - Laser - Legal, A4 - 1200 Dpi X 1200 Dpi - Up To 37 Ppm mono / Up To 37 Ppm color - Capacity: 650 Sheets - Usb, 10/100base-tx - Aficio Spc430dn 37ppm W/ Duplx & 550 Sheet Tray
My Ricoh Aficio SP C430 dn is displaying error code SC400. What does this mean?
It chimed and displayed error code SC400. I have tried turning it off then back on, but it chimes again and displays the error code. What is wrong with it?
Service manual for Ricoh Aficio SP 5200 DN with all parts and troubleshooting
go to service mode.
press up and down button. then press ok. go to SP5810 and reset.
Jan 29, 2017 | Ricoh Aficio SP 5200 DN Laser Printer
How do I print envelopes on Ricoh Aficio SP C430 DN?
You will have to change the paper tray settings on ricoh to match the settings in your driver too. Also being a Ricoh you may have to create a custom size with in the driver to get it to work. What size are the envelopes?
Apr 18, 2016 | Ricoh Office Equipment & Supplies
Spc 220n has a sc400 code
Process Control Error
This SC is issued if the process control adjustment fails 5 times consecutively after AIO
replacement.
• Defective contact at the terminal between the machine and AIO.
• Dirty TM sensor
1. Check the contact of the terminal and re-install the AIO.
2. Clean the TM sensor.
Apr 09, 2013 | Ricoh Aficio SP C220N Laser Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
Sc 400 code ricoh c221
An sc400 error means the toner mark sensor needs to be cleaned. Cleaning this sensor is easy:
Open the top cover and remove the cyan toner cartridge. You'll see a long black lever with a sort of handle that pokes upward -- slide this lever ONCE to the left, and then it should slide back into place.
Now replace the cyan cartridge and close the cover, and your printer should be fine. (If the error doesn't clear, turn the printer off and back on and it should go away.)
Aug 19, 2010 | Ricoh SP C221SF Aficio Printer
Ricoh Aficio SP 232 DN access code.
Call a Ricoh Technician to Reset the codes
May 30, 2010 | Ricoh Aficio SP C232DN Laser Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
RICOH AFICIO SP C411 DN COLOUR LASER PRINTER
Open the side cover, and unlatch the plate. The PCUs are located in there. In the replacement PCU, there should be instructions.
Apr 01, 2008 | Office Equipment & Supplies
RICOH - PRINTERS Ricoh Aficio Sp C430dn - Printer - Color - Duplex - Laser - Legal, A4 - 1200 Dpi X 1200 Dpi - Up To 37 Ppm mono / Up To 37 Ppm color - Capacity: 650 Sheets - Usb, 10/100base-tx - Aficio Spc430dn 37ppm W/ Duplx & 550 Sheet Tray Logo
2,004 people viewed this question
Top RICOH - PRINTERS Office Equipment & Supplies Experts
jasbo
jasbo
Are you a RICOH - PRINTERS Office Equipment and Supply Expert? Answer questions, earn points and help others
