Question about VIDAR Systems VIDAR TruScan Atlas
TruInfo does not recognize the vidar scanner, and I cannot scan with this scanner.
I'm using Windows XP and an Adaptec SCSI card. Windows XP recognizes the SCSI card and the scanner. However, the scanning software TruInfo does not recognize the scanner. I followed the instructions on contex's website for the Vidar Truscan flash p62. Any suggestions?
2 Suggested Answers
  • 5060 Answers
SOURCE: can the vidar truscan p-88
This scanner does black&white and gray-scale scanning but not color.
I hope this helps.
Posted on Aug 31, 2010
How do i use an epson filmscan 200 with a laptop running windows 7
were you using it under windows xp? if you have 32 bit windows 7 I would try those same drivers. Unfortunately the filmscan 200 came out under windows 95/98 and so Epson never released XP drivers and some people were able to make it work.
I would consider connecting it to an older computer running windows 98 and then transfer the files as you scan them (this would definitely be the least painful)
If you have 64 bit windows 7 I would not even waste the effort, 32 bit is a long shot maybe.
Do you have scsi drivers on the the windows 7? because the filmscan 200 is a scsi 2 device
Good luck
Nov 24, 2010 | Epson FilmScan 200 Film Scanner
Can you pls. suggest which PCI Xpres card support Fi-5530C2 Scanr
Hi Karthik,
Please click on the following link for recommended SCSI cards for your Fujitsu Fi-5530C2 scanner .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/scsi/
Please revert for further clarification.
Thanks & regards,
TechSatya
Jul 26, 2010 | Fujitsu Office Equipment & Supplies
Install XP on SCSI HDD - Instellistation Z Pro 6223-CTO
Have you tried putting the drivers on a flash drive.
It is a method I have used to get drivers into the windows install.
Try it with the "press F6 to install drivers" during the text setup phase but make sure they are the dos level drivers that you try first !
If that fails then try the windows level drivers
Worked quite well on lots of early SATA stuff so you have nothing to loose.
You might also want to check that the various usb settings in bios are set to legacy etc too.
Aug 20, 2009 | Computers & Internet
Adaptec AHA-2940 UW PCI SCSI CONTROLLER
If you are using Windows XP, the drivers are embedded. It will automatically recognize the SCSI card. For other OS try http://www.adaptec.com/en-US/support/scsi/2940/AHA-2940UW/ S. Mohan.
Jun 09, 2009 | Canon Office Equipment & Supplies
ADAPTEC 2940 SCSI CARD WILL NOT RECOGNIZE CANON DR-5020 SCANNER
. Have you installed DEvice Driver? Download item no 5. in this link http://software.canon-europe.com/products/0000672.asp
This should solve your problem.
S. Mohan, Chennai, India
Apr 02, 2009 | Adaptec 2940UZW ULTRA WIDE SCSI PCI...
Nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Mar 22, 2009 | Nikon LS 2000 Film Scanner
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
Nov 18, 2008 | Nikon CoolScan V ED Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
VIDAR Systems VIDAR TruScan Atlas Logo
74 people viewed this question
Top VIDAR Systems Office Equipment & Supplies Experts
k24674
Are you a VIDAR Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
