Question about Dell 924 All-in-One InkJet Printer
Carrier jam on printer
Went to scan document.started to make clunking noise,then paper jam came on screen. looked but no paper jam then it changed to clear carrier jam .Tried cleaning plastic strip,used air gas(staples suggestion),used regular air,unpluged everything,nothing works. still carrier jam.when try on computer it says printer busy. HELP!!!!!!
  • zippy5353 Oct 29, 2008
    Paper jam message - no paper jam. Turned off power - and back on several times. Still doesn't work.
  • Anonymous Oct 31, 2008
    The same is happening to my printer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
CLEAN CARRIER JAM
Open the access door on the back side of the printer to remove the jam.I once used some paper that always went into my printer two or more sheets at a time,causing a jam.I flipped the paper over ,then it would load a sheet at a time.Hope this helps?
Dec 20, 2009 | Dell 924 All-in-One InkJet Printer
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
"Clear the carrier jam" on DELL Printer 926
could something be stuck in the printer? clip/ paper/ dust
might be that simple!
Jan 24, 2009 | Dell 926 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Carrier jam on start makes clunking sounnd and stops
If your printer is making that clunking noise than stops, it may be that your encoder strip has come off the springs that hold it in place. That's what happened to our printer. Once we put the encoder strip back on the error message went away. If your encoder strip came off, it can be put back on! All you need is a flashlight, alot of patience, and small hands (I couldn't have done it without my wife!) Here's a link that helped us ensure the we put the encoder strip back on correctly : http://dellcustomerservice.com/support/topics/global.aspx/support/dsn/document?c=us&docid=45A49F4D2A17494E8F4B63951C8A1237&l=en&s=gen
May 09, 2008 | Lexmark Office Equipment & Supplies
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
358 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
