hi
the cable beside the connector that goes in to the pc has through time became twisted and i think some of the wires inside the cable may be snapped, i would like to know if there is any way to fix this problem, or do i have to buy a new cable
Comments:
Oct 29, 2008
- i had thought of that but it is to close to the connector to find them, i don't think i could do a continuity test either, just in case there is more than 1 wire snapped, i think i'll look for a pdf on the wiring diagram
thank you for your suggestions
yes if you can solder then cut the cable and solder the 15 pin vga connecter first test the continuty between the connecter and opposite end write it on paper then according to that solder all wires but better to buy new cable for long time
i have aopen 19" flat...main connection that goes to computer at rear of monitor is loose and...
(More)
i have aopen 19" flat...main connection that goes to computer at rear of monitor is loose and will not tighten...can i open monitor and fix this?
I have a Viewsonic VX715 The issue with this particular unit is that the picture goes blank few...
(More)
I have a Viewsonic VX715 The issue with this particular unit is that the picture goes blank few seconds after it is turned on. If you turn the lcd off, on, off, on, off, on, off, on. Or change a resolution a few times it eventually starts to work and works properly untill turned off for a certain amount of time. There is not much inside the lcd, only the power board and a signal input board, for a lack of a better name at this moment. The backlight is perfectly fine, picture and backlight are both not operative untill turned on and off a few times. Do I suspect correctly that the powerboard would be the issue in this case, its a single layer board it would not be too difficult to replace any of the components on the powersupply board if required. both inputs have the same issue, does not appear to be a input issue. picture / backlight come on and work perfectly for around 2-5 seconds at first, after which the display goes completely blank but power light remains green. resolution can be changed and the picture will return for a moment with good backlight as well, after a certain amount of on, off, on, off or resolution switching the display operates perfectly for unlimited amount of time untill turned off again after which - being cooled down the on off routine has to be repeated. I've had the display apart a few times now and I can not find anything wrong with the boards.
My monitor is getting off with a orange light while iam in work. This problem is getting with in 10...
(More)
My monitor is getting off with a orange light while iam in work. This problem is getting with in 10 min of using the pc. After that it wont get display but processor is working. once ishould switchoff the monitor and turned it means display willbe back with in 25 min. iam using the monitor is viewsonic 19" monitor. pls helpme from this problem.....
