Question about GE Refrigerators
GE Model GSS25SGPASS runs but will not cool. Was told to replace motherboard
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: i HAVE A GE GSS25SGPASS
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Take care.
Posted on Mar 02, 2011
I have a GE fridge model GSH25JSTSS and both the fridge and freezer are not cooling and the front panel is out (nothing lights up anymore on it). I've been told I need to replace the mother board, but it...
You need to test wiring harness and connectors, and control board. (motherboard) seems to have a control board problem.If your not getting 120 volts in the light socket then you have a board problem check for loose wire at the control board.Hope you rate my response.Thanks
Feb 03, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
GE profile refrigerator model # PDS22SCRRS not cooling. I looked in the back and condensor fan is not working. Should I assume that it needs a new motor or is it possibly the motherboard which I have read...
Check to see if you have 110 volts at the motor with the compressor running. If you do then your motor is bad - replace it. Also make sure something has not gotten in the fan to keep it from working. The fan must run to keep the compressor cool and from over heating. Be sure to put the back of the refrigerator back on when you are through.
Jul 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE side-by-side refrigerator/freezer that's not maintaining cold temperatures. I was told to replace the defrost thermostat which I did and it seemed to work for about a week or so. But now it's...
If the refrigerator isn’t cooling at all the motherboard is a good possibility burnt marks or not. If the fans are not running it could be a defective fan, motherboard or both. Take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the refrigerator isn’t defrosting properly, after a few days the freezer coils will get blocked out with heavy frost. There are four things that will cause this, defrost thermostat, defrost heater, evaporator thermistor and the motherboard. This page should help http://appliance-repair-it.com/GE-refrigerator-repair.html
Jul 17, 2010 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Side by Side Refrigerator no longer cooling.
If not cooling or signs of not defrosting we will need to check the compressor start components, fan mortors and motherboard. Let me know and I can guide you through this. Sea Breeze
Apr 04, 2010 | GE Refrigerators
Stoped cooling in freezer and refridgertor but lights are on . ge model psw26lsrdss
check the compressor and make sure it is running,if quite warm,replace the rtc overload on the side of the compressor first,this should solve your cooling problems,if there have been outages or surges, then you may need to replace the motherboard electronics in the lower rear of the unit,but with no cooling the first approach is much less expensive
Jan 25, 2010 | GE Refrigerators
Not cooling freezer/frig.
starts to work but then stops again? Yes that could be the motherboard but I would test the fan with direct voltage to see if it will run a long time.
Aug 14, 2009 | GE Profile PSS26NSTSS 25.5 Cu. Ft....
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Dec 09, 2008 | GE Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
