Question about Fujitsu LifeBook P1620 Notebook
Fujitsu lifebook p1620 typing wrong characters
Some of the anomalies when typig on my P1620: - When I go to hit the '.' , the screen will switch to portrait mode and '/.,mnvcs' will be typed instead - When I hit the '-', the Run box will open, as well at the Utility Manager and Microsoft Narrator and ''=-q' will be typed instead - When I hit the spacebar, 'gx' will be typed instead - When I hit the "_", '~+_)(UR$' will be typed instead - When I type the '>', '?>
4 Suggested Answers
  • 129 Answers
SOURCE: keyboard problem on fujitsu lifebook a6110
It may not be a issue with the keyboard. you mite have accidently pressed some point in the touch pad.
Posted on Feb 03, 2009
  • 59 Answers
SOURCE: need to reattach the W key on my Fujitsu Lifebook P7230
You may have broken a plastic "hinge", more like a tab or clip. Try taking it off again and examine the underside of the key. If it looks ok, try putting it back on. If a plastic tab/clip is broken on the left side, you should be able to go to a small computer repair shop and get a replacement key for it. That way you don't have to replace the keyboard.
Posted on Jan 04, 2010
  • 1768 Answers
SOURCE: where can I get a complete operating manual
the place to get schematics and service manual are at the source the Fujitsu site.
They have the service manual and the resources to repair.
Posted on Apr 13, 2010
Vista has handwriting recognition built in. XP doesn't. If you have a tablet,...
NOTE: This Tip can be Hard, I recommend Advanced Users Only.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we'll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don't just use the default. I chose roughly 10gb by entering 10000 into the amount.
This step might be confusing, because we need to change the cd-rom drive that's invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it's already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn't the end of the world, but it's not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we'll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it's easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you'd like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can't do the next step until we reboot. (you can try, but it won't work)
So we've come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like "XP". It would be wise to name the C: drive to "Vista" at this point as well.
Now you'll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like "Hit Esc for boot menu" you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don't try and install onto your Vista partition! See how much cleaner it is now that we've labeled each partition distinctly?
We'll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we'll need to use the VistaBootPro utility to restore the Vista boot loader.
Download and install VistaBootPro from
During the install you'll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the "Windows Vista Bootloader" and then "All Drives" radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you'll only be able to boot into Vista, but we'll fix that. Instead of manually doing the work, we'll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the "Manage OS Entries" tab and then click in the textbox for Rename OS Entry, and name it something useful like "Windows XP" or "The Windows That Works"
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying "unable to find ntldr" when trying to boot XP, you'll need to do the following:
  • Find the hidden files ntldr and in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can't find the files there, you can find them in the \i386\ folder on your XP install cd
You can share information between the drives, but I wouldn't recommend messing with the other operating system's partition too much… it might screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition "Data".
This works if you have the operation system "Windows Vista."
on Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Fault code P1620
P1620 code is a thermostat error. it's a picky sensor, and unless you notice anything wrong (like a rough idle, or problems with the operating temperature) I'd ignore it. If you are having issues you may need to replace the MAF sensor located in the thermostat on top of the engine
Feb 07, 2013 | BMW Cars & Trucks
Touch screen on ubuntu lifebook
The touchscreen will only work if there is a driver released by fujitsu for your version of ubuntu. Did you find and install one?
Dec 21, 2012 | Fujitsu LifeBook P1620 Notebook
Fujitsu lifebook is typing the wrong characters
Try the "On-Screen" keyboard to see if it types the wrong characters as well. If not, then you have a bad keyboard.
Oct 29, 2010 | Computers & Internet
Keyboard types some wrong characters
Usally means its set to the wrong country keyboard type, change it in control panel, locations.
Aug 31, 2010 | Fujitsu LifeBook A6010 Notebook
P1620 dtc what can i do what can i do to solve this code
this codes points to low coolant level or a bad sensor for it
May 05, 2010 | 1997 Saturn SL
Where can I get a complete operating manual
Apr 13, 2010 | Fujitsu LifeBook P1620 Notebook
Blue screen asking for password
if this happens before you see a windows (assuming that is your OS) screen, chances are it is a password that is prompted by the bios. you will either need the password from whereever you got the computer or use another computer and get a program that can retrieve a bios password from the eeprom.
May 06, 2009 | Computers & Internet
Keys enter wrong characters
You have Num Lock on. Turn it off.Generally Function and End or one of those keys.
Feb 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Fujitsu LifeBook P1620  Notebook Logo
46 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
