Question about MSI P965 Platinum Motherboard
HDD Installation Hi, I Want to install a new HDD (WD, 500GB). This is the third hard disc on this board. Which port should I use? My first disc is on SATA 1, my second disc is on the additional connect down below and the third disc (new one) dosen't work! It is hot, so I think it turns, but my computer manager dosen't find it.
  • 101 Answers
If the WD drive is SATA 2 and the m/b is "older", try putting a jumper on 5&6.
Posted on Nov 19, 2008
    President:
  • 2,351 Answers
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
HDD Installation - 2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Posted on Oct 28, 2008
Cyclic redundancy error with my HDD WD 500gb - used on a Samsung TV32eh54. I kept the HDD plugged into TV for several weeks, Might this be the problem?
Hiii friends,
I too had lost some of my files from WD hard drive recently. So in order to recover data from WD hard drive I used WD Caviar Hard Drive Recovery, which scans entire hard drive within few minutes and retrieves each and every file. You can download it from internet for trial usage.
Dec 25, 2012 | Samsung Computers & Internet
Hi guys, i have a new WDbluecavier 500Gb,16Mb cache but the allocate space is 467978..so how can locate the remaining space??
This is the real capacity of your 500 GB hard disk - they are measuring it incorrectly for commercial reasons (in reality it's just 488GB) and there is a part that is reserved internally. There is nothing else.
Jun 01, 2011 | Western Digital WD HDD 500GB SATA 25"...
Can i connect 500GB sata hard disc and 2 - 2GB ddr2 RAM to this mother board????
The motherboard will take a 500GB SATA hard drive as there are 4 SATA ports on the board. As for the memory then it will only take 2GB maximum.
Regards.
Dec 15, 2010 | Intel D945GCCR Motherboard
Lost my installation CD for my Western Digial external hard drive
WD My book does not need driver to run on Windows, however you can download software for all Operative systems here:
My Book
If the direct link does not work, start from this page to locate the download: WD Support > Downloads > Select Product
May 30, 2009 | Western Digital 500GB My Book World...
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
No installation disc, but apparently i didnt need one
I bought the same product, I noticed that connecting the device to the USB ports at the back of the PC body and using shorter cable solved the problem, try each of the ports at the back of the PC.
Jan 25, 2009 | Western Digital Elements powered by WD 320...
I replaced a bad 120 gb hard drive with a WD 500gb sata hard drive. Installation went fine, however I am having trouble with the reinstall of the XP system. It freezes up at the point where it asks if you...
First, I would remove the 120 from the system during installation. If possible, use a Windows XP disc w/ SP2 to speed up installation of the OS. Plus SP2 handles a maximum disk size error which limits you maximum partition size. (Under SP1 I think the largest partition can be 137 MB)
I would recommend using NTFS format for the hard drive.
Once it is installed, you can always re-connect it to simplify the installation.
If it's still freezing, check the disc for damage or defects.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
For installation of sata h. drive
ad8d69d.jpgif u can open the cpu cabinet, check on the motherboard if u have a slot as shown in the left picture.. if it has, then u can connect the sata hard disk. if not ur motherboard only has ide connectivity.
May 15, 2008 | Intel Motherboard
MSI P965 Platinum Motherboard Logo
176 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
