Question about Compaq Presario Notebook
I can't setup windows xp sp2 in my laptop
When i put the cd of windows xp sp2 can't find my hard disk compaq presario v6000
  • Frank
    Frank May 11, 2010
    how are you installing the SP2 ???? Windows XP now have SP3
  • 33 Answers
Reboot and click F10 as it boots; you'll see a boot order setting -- change this to CD-ROM first and save/exit.
Posted on Oct 28, 2008
    Problem Solver:
  • 15 Answers
Why bother, go on the net and search for windows updates. dont use windows but another 3rd party site, they have all the updates to do this. i run my system on the earliest xp windows. i have to load sp1, sp2 and sp3, do you think i am going to wait 3 hours to download all the updates. 5 hours it took with the damn thing keep on switching on and off. now i load 1, 2 and 3, an hour and its all done. then just update for the extras which is malicious software update and a few security updates.
Black screen v6000 laptop "HELP Please"
It appears the hard disk has been wiped/formatted and does not have an operating system installed.
You need to get a Windows Vista installation CD and if the Windows label on the bottom of the laptop is still attached then this label has the product installation code.
Boot up with the Windows Vista installation CD to install the Vista operating software then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 19, 2012 | Compaq Computers & Internet
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
My laptop is compaq presario v6000 when i try to format it or setup a new version of windows xp it says ntldr file is missing and press ctr+alt+del to restart.but whenever i restart with the xp cd in the...
when you see the compaq screen press the f10 key then go to boot sequncing a make sure it says cd rom than hard drive try to find this option. Then save the settings and put the xp cd in then reboot again and it sood enter windows xp setup.
Jan 17, 2010 | Acer Aspire 5920 Notebook PC
Installing XP pro on my presario C700
restart the machine and press f10 to enter BIOS.
select exit and select load setup default. and exit.
install Xp Opearting system
May 29, 2009 | Compaq Presario 700 470024-192 Notebook
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Os loading
go to the bios , change the hard disk support from native to legacy
Oct 31, 2008 | Compaq Presario Notebook
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
Install xp-sp2 on compaq e500
First tell that which O/S it had earlier coz armada e500 notebook comes with 64 MB RAM and 12 GB HARD DISK , had you upgraded your notebook with RAM AND HARD DISK .
If not then check the hard disk space you have left in the notebook.
Apr 25, 2008 | Compaq Armada E500 Notebook
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Compaq Presario Notebook Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
