Question about Yamaha RX-V793
Yamaha RX-V793 flashing light on volume control and no volume
For no particular reason, one day i turned on the reciever to watch a movie and there was no sound. The volume dial has a light and it is blinking. any idea? checked all my connections, turned on and off and no change. everything seems to be fine, except the blinking light and no sound. thanks, Sidney
  • mlst Apr 09, 2008
    no sound but light blinking on volume control
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Posted on Sep 12, 2006
    New Friend:
There is a way to bypass the remote control if it is missing or defective. Enter Diagnostic mode by turning the receiver on while holding DVD/LD + preset button number 8.
Once in diagnostic mode, press preset button 7. twice to get to factory preset option. (Assuming you are fine with this of course).
Then turn the receiver off and on again,
Done :)
Posted on Jul 22, 2016
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
Yamaha RX-V793 The volume changes from low to high by itself. Is this a blown channel?
You have a bad Rotary Encoder(what you think of as a volume control) It is not a variable resistor, as in decades past. It is an input to a microprocessor(a computer within your Yamaha). If you require additional assistance, or would like to inquire about repairing your Yamaha, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 18, 2014 | Yamaha Audio Players & Recorders
Receiver suddenly turns off
If you have the vollume control set around 40, End watching a movie if there is a loud burst in vollume,It is causeing the reciever to run over it,s wattage rateing. End over heating,When it,s shuts down, It went into what is called the protection mode.Keep it at a lower vollume then it willnot do that.Allso what can cause it to do that, If you have your output leval control on your sub turn right up.
Oct 17, 2012 | Yamaha RX-V665 Receiver
Yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Apr 02, 2012 | Audio Players & Recorders
Yamaha RX-V793 receiver shuts down when I turn up volume. Checked the speaker wires and they seem okay. I then hooked it up to an older DVD player I had and it works fine. Don't know if it's 5.1 bu
My first thought would be that when you moved the receiver to connect another DVD, the problem quit since the speaker wires moved. The best way to test would be to re connect the original unit the same way as the new unit and test again. If it still cuts out, disconnect the speaker wires and re test. if it still cuts out, try the new player and test again. if it does not cut out, there may be a problem with the old units audio output. Generally if its a problem with the receiver it would not matter what source you are using, even the tuner on the receiver, if there was a short in the receiver it would cut out. Let me know what your results are and I will help more if needed. Best of luck!
Nov 24, 2011 | Yamaha Audio Players & Recorders
Volume on Tv/dbs mode extremely low......volume works fine on tuner any ideas? This is a Yamaha RX-V793 thanks
I have the same problem, I'm thinking that the equipment is old and I need a new one. need an answer too!!!!
Nov 05, 2009 | Audio Players & Recorders
Sound Control
unfortunately outside of turning down the volume. there isnt anything you can do. the reason that is is because its the networks own volume preferences that cause that. the only way you can fix is it call them and tell em to turn down the damn commercials. lol. sorry
Feb 21, 2009 | Yamaha Audio Players & Recorders
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
Flashing volume control
THE MUTING CIRCUIT IS ON AND IT CANNOT BE DEACTIVATED BY UNPLUGGING UNIT...YOU MUST HAVE THE REMOTE TO DEACTIVATE.
Sep 10, 2006 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha RX-V793 Logo
1,858 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
