Question about HP LaserJet 5p Printer
LaerJet 5p Extra page prints with code
LaserJet 5p prints extra page before my document with following code at top:
+OFF@PJL SET PAGEPRPTECT=AUTO
@PJL SET RET=MEDIUM
@PJL SET ECONOMODE OFF
@PJL SET R
  • BJanke Oct 28, 2008
    Most, but not all print jobs. I am the only user---no network
  • Frank
    Frank May 11, 2010
    every print job??
    are you the only one using it or it is used on the network, if so, does evry one have the same problem??
    Genius:
  • 1,605 Answers
Check all your application.(word, Excel) by going into print preview, you might have a single black page at the begining. ( this happens when you save the templete with a blank page.)
if that is not, let me know. got to go one step at atime.
Posted on Oct 28, 2008
Hp laserjet 4200 will print a 50 page paper path test, print an extra page and then jam.
The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
Oct 03, 2012 | HP LaserJet 4200 Printer
HP Printer not printing, activated error code -20
Error 20 Memory Overflow / Insufficient Memory
  • A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
  • On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
  • On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
Nov 24, 2009 | HP Office Equipment & Supplies
An extra page with al the details about the page is being printed
Does this happen when you print a test page ?
What programs does this happen from?
Microsoft office... ect.. Try printing from a different program, and let us know if the extra page of details prints or if it is just one program
Jun 25, 2009 | HP LaserJet 1020 Printer
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
<ESC>%-12345X@PJL DEFAULT DENSITY=4
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
Or:
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
LaserJet 5p extra page prints first with code
When you get that kind of information those are instructions to the printer. It has been my experience that the drivers loaded for the printer are not the correct ones. Check to make sure that you have the drivers for a HP 5P printer and verify that is what kind a printer you have.
Oct 28, 2008 | HP LaserJet 5p Printer
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Print is garbled with PJL commands
unplug printer then plug in again and reboot computer
May 24, 2008 | HP LaserJet 5p Printer
Hp laserjet 1300 prints extra blank page
did you try the hp laserjetIII driver
Apr 22, 2008 | HP LaserJet 1300 Printer
HP LaserJet 5p Printer Logo
606 people viewed this question
Seeker5211
Seeker5211
