Question about KitchenAid Ovens
KITCHENAID OVEN MODEL KEBS277DBL
Hi
I purchased the double ovens in April 2001. I have had no issues until the last two months with the top/convection oven. When I shut the oven off and the fan has cooled the oven down and turned off, the panel after approximately 5 - 10 minutes beeps and every possible light on the panel flashes on and off leaving just the Power Failure(PF) light showing. Sometimes it blows the clock out so I have to reset it. I have been using the lower oven, that one does not cause any of those issues, just is not heating up as well
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
  • 1314 Answers
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Posted on Mar 30, 2008
  • 3 Answers
SOURCE: DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Posted on May 30, 2008
  • 3422 Answers
SOURCE: Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Posted on Sep 17, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Gas oven does not light
I called the service where the item was purchased.
You were no help at all
Dec 03, 2009 | KitchenAid Ovens
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Jan 30, 2008 | Thermador SC302T Electric Double Oven
DOUBLE OVENS FROM KITCHENAID
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Mar 22, 2007 | KitchenAid Architect Series KEBC278KSS...
Ovens Logo
158 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
