Question about LG enV VX9900 Cellular Phone
My enV read use genuine battery and counts to 10 and then shuts down what can I do. Tremaine31736@yahoo.com
  • 7 more comments
  • jleehwang Nov 24, 2008
    me too! i don't know what to do about it. i'm trying to turn it on but it doesn't work.
  • joneseyjones Nov 27, 2008
    Same problem here. The phone is brand new, plenty of juice left, but getting the "Use genuine battery" message, can't turn phone on.
  • smc4102 Nov 29, 2008
    It is the same thing genuine battery problem how do you fix it?
  • tyler123 Dec 03, 2008
    mines does that too. i've tried contacting BOTH verizon and LG and they are no help.
  • Anonymous Dec 12, 2008
    dis friction sucks du
  • Anonymous Jan 17, 2009
    If my phone ever dies or is shut off whenever i try to turn it back on i get a message that says please use genuine battery and than it shuts off
  • Anonymous Jan 18, 2009
    my phone says the same thing with using genuine battery and then powers off in 10.
  • Keys1018 Jan 27, 2009
    I'm having the same problem with my enV 2. Verizon sent a replacement phone, but the new one is doing the same thing. They're sending me a new battery now, but I'm not holding my breath. I tried to get them to replace it with a new phone (different model) but they don't seem to like doing that. So now my phone is dead, it won't turn on, it won't charge, and I won't have my new battery until tomorrow. Which means I have to drive home tonight in what's supposed to be a blizzard, on back country roads, with no cell phone. Thanks Verizon.
  • Anonymous Mar 10, 2009
    mine has been dead for over a week now and it has the verizon logo come on too when I plug it in but it flashes sporadically between that one and "battery is required" and still doesn't work. I got a new battery for it and it looked like it was charging at first but went back to the same verizon and "battery is required" messages....so I'm looking for a new phone....
I got this same message and got so mad at my phone that I finally started getting really drastic with my choices on how to fix it. First I took an eraser and rubbed it on the battery and where the battery means the phone. Thinking that maybe it was dirty or something. I don't know if I saw that solution from here or somewhere else be someone said to do it and it didn't work, but you should try it just in case. Then I took a Q-tip and dipped it in some rubbing alcohol. I rubbed it on the same spot where the battery meets the phone and on the battery and it didn't work either, but still try it. It may work for you. Eventually I gave up because it sucks to sit through ever attempt and hope that it works when it doesn't. I just sat there with my phone and turned it on and off and watched the message in boredom, but them my phone finally died. So I just put in on my dresser and forgot about it for a while. I woke up the next day and had plans to check my phone and I couldn't find it, then I remembered that it was broken and got up to go get it off my dresser. I tried turning it on but it was still dead. So I just decided to pug it in and attempt to have another day of desperate attempts to fix it but instead of it just saying 'use genuine batter' and staying like that, it had a message the said 'battery charging' and while it said that a picture of a battery beneath it flashed. I was confused because 1. I’ve never seen this message before and 2. I’ve tried plugging it in before but it still didn't work. So I pressed the power button while it was still plugged in just to see what would happen and it turned on like normal. the verizon wireless label came up and my normal screen came up. So maybe you should just let your battery die and leaving it dead for at least 8-15 hours then plugging it in and turning it on while it is plugged in. It was…extremely relieving.
Posted on Dec 19, 2008
  • cdjustice Oct 15, 2010
    I dropped my LG and it cut off. When I tried turning it back on it said replace battery with genuine battery and started counting down from ten and would cut off. I read Perk_Orgon reply below about trying the rubbing alcohol. I put some rubbing alcohol on a tissue and dabbed it on the battery contacts in the phone and then on the battery itself. I waited about five minutes, placed the battery back into the phone, hit the power button, and to my surprise the phone turned on and worked fine!! :) Thanks for the tip!!!
    Problem Solver:
  • 6 Answers
Well I have the enV as well. The phone has a lot of problems, the most popular is the Use genuine battery error. It happens when the phone is forced off. By things such as the battery falling out,the battery dying, or dropping your phone and it goes off. It usually says the error message for about 2-6 hours. So when it happens you just need to keep trying to put it on every couple of hours. Well hoped I helped a little bit.
Posted on May 20, 2009
  • 5 Answers
That previous post was good for a laugh and it worked! Cleaning the contacts for the battery connection (on the battery and the phone) did solve my problem. Make sure when you clean any contacts/elcectronics with rubbing alcohol that you wait a few minutes for it to completely dry before re-installing the battery.
Posted on May 16, 2009
I have the same problem. Best thing I can tell you is to avoid cutting your phone off at all. Make it a last resort. Otherwise you have to wait awhile before it works again.
Posted on Jan 06, 2009
My Verizon LG EnV3 is saying Use genuine battery and then powers down in 10 seconds. I've tried most of the suggestions people have posted and they haven't worked. Please help! I don't kno
I had 3 Verizon LG VX 5500 and 1 told me the same thing. I just ask a friend for an old phone and then I activate it on the verizon website and no problem... it can't be fixed once is asking you for a GENUINE BATTERY, you need to get another phone. Also you can get the same phone in ebay (used) and activated it yourself.
Mar 25, 2013 | LG enV VX9900 Cellular Phone
I have an enV 2, about 2-3 years old.I dropped my phone in the toilet, for 3 seconds, dried it with a towel, let it sit for 5 mins, put it in front of a fan for about 7 mins, and put it in rice for 30...
Yo! the drying system you used is not enough to dry it. you need to open it up to the best you can and dry under the sun for hours or under **** heat. that should do. thanks
Jul 25, 2011 | LG enV VX9900 Cellular Phone
Whe.i try to turn it on it says verizon for while and then it says use genuine battery and it counts down 10-0 and it shuts of.
there is some sort of problem with your battery, it has (some) reason to think that the battery installed is not made well/ by their company and cannot operate because it does not have the proper power output. getting a new battery will fix the problem. remember to vote
Mar 17, 2011 | Cell Phones
My lg vx9900 shuts down at random times. when i turn it back on it says "use genuine batter" then does a count down from 10 and shuts back off
Take the battery out and wiped it off with a clean, dry cloth and try again.If is still doesnt work buy a new battery
Jan 10, 2010 | LG enV VX9900 Cellular Phone
Phone wont turn on
Your phone is detecting a not genuine battery.You should use a genuine battery for your phone to avoid this kind of warning.
Dec 15, 2009 | LG VOYAGER VX10000 Cellular Phone
Why does the EnV refuse to have peace with me? I'm on my 6th or 7th. The charger kept breaking loose on the inside of the phone, the screens crack for no reason, and the most recent 2 phones have given me...
Sounds like you have a bad unit ir one with the original software. look on the "about" icon or the menu and see if you can find the version of phone / software load. It may also be behind the battery. Google that version and see if anyone else has had those issues. I dont know how long you have had it, I always wait for a few months after they announce new phones, til the figure the bugs out of them...
Jan 06, 2009 | LG enV VX9900 Cellular Phone
When turned on says "Use genuine battery" and when try to charge
I had the same "Replace with genuine battery" then the 10.9.8.7... countdown. Thought the damn thing was going to blow up!! Verizon switched batteries and told me the phone was dead and that they couldn't get any of my contact phone numbers off of it. Wanted to stick the ticking time bomb up their you know what. Never had any problems with the phone let alone never getting it wet. Anyway I didn't fall for their buy a new phone scheme and left the non customer service store fuming. The next day I had an old dinosaur Verizon phone activated to at least have a phone. Went home and checked a few websites for advice. One I came across made the most sense. Rubbing alcohol on the battery contacts and blow dry off using a hair dryer on the cold position for 20 minutes. Use a cotton swab and gently wipe the battery prong contacts on the phone itself as well as the battery contacts. I also wiped down the inside of the battery charging slot. Popped the battery back in and just like magic..... the phone was back from the dead. Told Verizon about the cure and they shrugged their shoulders. This works trust me and don't fall for their buy another new phone gimmick. Can you hear me now? NOOOOO
Dec 06, 2008 | LG enV VX9900 Cellular Phone
LG 9400 cell phone
take it back to verizon. unless your using a 2nd hand battery
Aug 31, 2008 | LG VX9400 Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
LG enV VX9900 Cellular Phone Logo
3,827 people viewed this question
Top LG Cell Phones Experts
kenneth njonjo
Vorked Entertainment...
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
