Question about Toshiba CZ27V51 27" TV
TV not coming on...
When I push the button to turn on my TV, the red LED light flashes off and on. The TV does not come up. But when I turn it off the screen fades from black to a small dim light quickly as though its been on. There is no sound so I think it may not actually come on. Do anyone now what is happening with the TV?
  • 3 more comments
  • Anonymous Nov 18, 2007
    I have the same problem (it began after a slight fall), but unplugging doesn't help. Anhy other ideas?
  • chicagodee Nov 20, 2007
    Same problem here. No pic, red LED light flashes. I disconnected the TV and reconnected after a bit, still doesn't work. Any suggestions?
  • Vacdude Nov 25, 2007
    I have this same problem. Has anyone come up with a solution for this? The LED light just blinks when the tv is turned on. It doesn't happen all the time. But it seems to be happening more frequently lately.
  • Pragmatic Feb 11, 2008
    Same problem here. Any luck on the repair?
  • tirujai Apr 07, 2008
    Same problem here . Tv comes on and then shuts off in 15mins amd sometimes 30mins. Have been doing it lately very often. Any solution found yet
    New Friend:
Switch it off en unplug it aftr one hour switch it back
Posted on Apr 12, 2014
Unplugging it seems to have done the trick. Thanks for this site!
Posted on Oct 09, 2008
I just called a Toshiba repair center this morning...they said it has something to do with the power supply, but can't be sure until they open it up and take a look. I was given a ballpark quote of $125 to fix. I'm taking it in on Saturday.
Posted on Nov 20, 2007
The same thing happened with my T.V. (although it is an RCA). The first time a repair man charged me $75.00 to fix. The next time we were told to just try unplugging it for a few minutes then plug back in...that worked. T.V. still sometimes does this, unplugging it fixes the problem
Posted on Sep 03, 2006
Is it hooked up to a vcr or dvd? it sounds like what mine does when i have it in Video 1 or Video 2 mode. keep changing the mode until it is back in TV mode.
Posted on Jan 25, 2009
SOURCE:
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
When trying to set up my new SRP2008B remote should the TV be on or in standby mode? In step 2 should the red LED be flashing or stationary? The Quick start guide is somewhat ambigious about these two...
U are setting up a universal remote?Yes,tv should be on,second push the search button on the remote,should be flashing and enter all those codes provided by the manual one by one the LED light of the remote should be solid red as the codes enter one by one the red light and go off and pushing the on/ff button on the universal remote for each codes as u got the wright codes the tv will turn itself off.
Apr 11, 2011 | Philips Televison & Video
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
TV WONT START UP - RED LIGHT COMES ON AND THERE IS A CLICKING NOISE AS IF IT IS TRYING TO RE START - IS IT THE LAMP UNIT OR STARTER?
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    Dec 05, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
    THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
    This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
    Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    View timer only lights
    TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
    Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
    Won't turn on
    I have the same problem....read somewhere that it is a "motherboard" in the front of the TV...Still looking for the solution to this one.
    Feb 13, 2008 | Philips 27PT81S 27" TV
    Hdtv won't turn on
    Can you count how many times it flashes ? It might flash like 6 times and pause for 2 sec and flash 6 times again. THen call a service comany and tell them this info and they might tell you what part inside is bad. They are not telling you this for you to replace but they might say something like oh 6 flashes is a Y board and we will have to order it.
    Hope this helps
    Aug 29, 2007 | Televison & Video
    Toshiba CZ27V51 27" TV Logo
    468 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
