Question about Lexmark X5150 All-In-One InkJet Printer
OCD Scan not working.
My Lexmark 5100Se is not scanning text. When I try, it scans like a photocopy and reports to install my OCR software and try the scan again. I have pulled the original Lexmark installation CD and reinstalled it, but it goes through the whole process, declares it has been installed and it does not help. I hve both used the UPDATE factor and have even uninstalled and reinstalled it. Still can not activate the scanner to do the optial character read scanning. This used to work beautifully. Anyone know...?
IB4G2008
  • 3587 Answers
SOURCE: OCR
yeppers..and you might find that through this link to lexmark(see icon)
Posted on Mar 23, 2008
SOURCE: ocr folder
The software you need is Abbyy Sprint OCR. If it's not installed, I suggest running the printer setup again, making sure it's selected when you get to the software list. Perhaps you unchecked the box when you ran the installation the first time, or didn't know what it was and uninstalled it from your computer. You may be able to find it by hunting through the CD, but it will probably be easier to run the setup again.
Posted on Jan 19, 2009
  • 468 Answers
SOURCE: I want to install the OCR (scan as text) software
Without CD you can't install OCR or Optical character recognition software because OCR function is not installed in scanner but in computer. Usually when you buy new scanner you get CD or DVD with drivers and some lite version of OCR and some other programs for graphic editing.
Posted on Oct 24, 2009
SOURCE: i install the software.printer is works,but when i
I have a lexmark X5650 and the the little window will show copy but it wont do noting else i have window vista but when i hook it up to window xp it work will it work on window vista
Posted on Jan 09, 2010
mpapog
  • 148 Answers
SOURCE: i using lexmark x215 i dont have cd but i
  1. Check the connections between the two machines.
  2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  4. Close the printer's document lid slowly so the document does not shift position.
  5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  6. Push the scan button. You may have to do this on the printer itself or on your computer.
  7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.StepAccept the scan and save. Return the original document to a safe location.
Posted on Feb 24, 2010
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
I have a Lexmark x5650. I'm on a mac, upgraded my os from Tiger to Snow Leopard. Now I can't scan OCR text. Could scan to word document before, and get editable text. That is not an option now
If you still have the Lexmark X5650 install disc that came with your printer, re-insert it to your computer hard drive and run the program. This will help repair the OCR scan software and possible corrupted files necessary for scanning documents.
Jan 12, 2012 | Lexmark X5650 AllInOne InkJet Printer
I need OCR folder for lexmark x4530
You can download and install the Lexmark OCR scan software using the installation disc that came with your printer only. The software is not available for downloading online.
If you lost the disc, please contact Lexmark Technical Support Center to request for one. Thanks.
Nov 11, 2011 | Lexmark X4530 InkJet Printer
I need to scan a printed page into a txt file using Notepad. Gone through the Lexmark Imaging option and attempted to scan, Come up with a message about installing OCR software. I can't find original...
The Lexmark OCR scan software allows you to scan documents to your computer. It enables you to scan to PDF or scan a document and convert to text to edit. The Lexmark OCR scan software is only available in the install disk that came with your printer. Please contact Lexmark technical support for assistance. Thanks.
Nov 12, 2010 | Lexmark X2350 All-In-One InkJet Printer
Scanning - edit text
The scan software(OCR) can only be installed using the installation cd that came with your printer. It's not available for download since it's a big file. If you have the installation cd, just insert it in your computer to install the software. If you don't have or you lost it, I advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275). They will be able to send you one for free. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 23, 2010 | Lexmark All-in-One Printer with PictBridge
I want to install the OCR (scan as text) software for my Lexmark X1270. It worked on my old computer, but on my new one it tells me to use my CD, which I don't have any more. I've tried re-installing the...
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
Wanting to scan to microsoft word
Please note that the OCR software is a third party software which is available in the Lexmark Installation CD itself. However, please click on the link given below to download the trail version of the OCR software:
http://www.download3000.com/download-abbyy-finereader-8-professional-edition-count-reg-46361.html
Apr 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X2500 driver is missing OCR software
Sometimes companies only support only the basic drivers. The OCR software is on the CD (s) that came with the printer. Suggestion. Try to order the original CD from Lexmark., or search Ebay for programs that have OCR capability. You can use OCR programs from other vendors as long as they are stand-a-lone programs. Just make sure you have the original disc so as not to infringe on copyright privileges.
Note: you can buy OCR programs. Check Ebay and Amazon. They are usually better that the programs that come on the OEM disk.
Cheers.
Mar 27, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X5150 All-In-One InkJet Printer Logo
148 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
