Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Poulan p3416 no spark
New ignition module, no spark
  • 4088 Answers
SOURCE: poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Posted on Sep 01, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan p3416 runs for a short time....stalls and
Immediately after it stalls do this:
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If spark good:
When it begins to stall loosen fuel cap if that fixes it fuel vent problem.
If spark and vent good it is most likely a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor.
Was this saw perhaps operated without oil mixed with the fuel?
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and inspect the cylinder, above the exhaust port, through the spark plug hole. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered. HTH
Lou
This will even work on a Chinese McCulloch 3416. If this is a Mac it may be very difficult to find a repair shop willing to repair it.
Posted on Oct 11, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan p3416 .3 1/2 years old . gas cap has become
Poulan.com
http://www.ordertree.com/modelinfo/PWE/P3416-Gas-Saw-Type-2/75.P3416-Gas-Saw-Type-2.1.59.1.html
Handle, Chassis, & Bar Assembly
Item 15, $3.09
Maybe a little cross threaded or swolen from contact with fuel.
Please verify this is your fuel cap. HTH
Lou
Posted on Oct 29, 2009
  • 4088 Answers
SOURCE: what is the gap for the ignition module on a
A thin business card is just right for setting the gap. Turn the magnets to be under the module poles, loosen the module screws and allow it to stick to the magnets. Tighten the screws, rotate the magnets away and remove the card. If the module is good it should make a snappy blue spark with a new plug. If rotating the flywheel through one revolution causes any core rubbing, the crankshaft may be bent or the flywheel may not be fully seated on the crank shaft. Don't run the engine until this problem is repaired. Hope this helps!
Posted on May 10, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I've replaced the ignition module on my Poulan Pro
The spark should be blue in color not orange or white. A bluish ornage is ok. The easiest was to set the gap is to tear off the front and back of a match book cover tear it in half and place the 2 pieces between the module and the flywheel losen the module and let it slide against the match book cover. Tighten the mounting screws and then turn the flywheel to remove the match book cover. <- (Been doing this for 40 years!)
I suspect your problem may be fuel / carb related vs ignition.
However.... a bad spark plug will spark when removed and you have grounded the electrode end to the engine but will NOT work when you install it. Make sure you change the plug. (FYI I have seen new Champion mini plugs fail right out of the box.) I have had as many as 3 in a single NEW box of plugs fail.
Just for grins try adding a splash of gas into the spark plug hole or carb throat before you try and start it. If you get a momentary start you have carb / fuel supply problems.
If you discover you have carb / fuel problems just repsond and we can proceed with getting you going again. I will help you.
Thanks for Choosing FixYa
Kelly
Posted on Oct 03, 2010
I just bought a new Poulan Model P3416 chaisaw (34cc) and I have followed the starting instructions and have not been able to start the saw. I have even varied the instructions but no luck. Any thoughts...
see if your switch is in run position and then pull your spark plug out see if it is wet, then see if it is sparking when you ground it and pull cord to roll over, if all is good hold throttle wide open and crank over without choke on, probably flooded, good luck
Aug 19, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Poulon chain saw model 2175 no spark. What to check?
Remove the starter assembly and left side cover to expose the flywheel and ignition module after trying a new spark plug gapped at 0.020". Remove the ignition switch wire from the module and try for spark again--if still nothing, use a thin business card for a gap gauge between the flywheel magnets and the module poles. Loosen the mounting screws, let the module contact the magnets through the card, then tighten the screws. Try for spark again--if still nothing, replace the module. Use the above procedure to install the new part. Hope this helps!
Aug 05, 2010 | Poulan Garden
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan p3416 .3 1/2 years old . gas cap has become really tight,from the first turn
Poulan.com
Item 15, $3.09
Lou
Oct 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan saw wont start has spark and fuel
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42 chainsaw will not start
I had the same problem on a P3416 saw. I had a new Champion plug and coil installed. I tested the plug by removing it and plugging it in the coil wire and ground the end of the plug on the engine block. It did not spark so I bought another plug. This one fired but it was real weak so I loosen the coil and slipped a piece of light folder paper between the coil and magnets and tighten the bolts. Got a better spark and got it to run.
Mar 04, 2009 | Garden
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
62 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
