Question about Apex Digital AT3208S 32" TV
My tv/jcv (i have no clue of type) keeps zooming
My tv zoomes in and cuts a chunk out of the left and the right side and i can only see a bit of the tv can somone plz help me :(
Take your remote control, press volume to 0
Press the mute button on your remote, at the same time, press the menu button on your TV for 3 seconds.
A menu will apear, press the right arrow on your remote to go to menu 002 to fix your problem.
Posted on Dec 29, 2008
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
TV stuck in zoom mode (heads are cut off)
on your remote try this..... push the left or right arrow keys to change format
Jan 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Jan 07, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Aug 14, 2008 | Samsung TX-R3075WH 30" TV
I have the lg env2 and i can not figure out to zoom in and out on the camera and it not the arrows
You need to make sure that your camera isn't set in the highest setting. Otherwise there's no zoom available.
Aug 11, 2008 | LG Cell Phones
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Zooming
on the side of the phone theres a left/right arrow
next to the mp3 button.
left zoom out right zoom in.
Jan 17, 2008 | LG Shine KE970 Cellular Phone
Heads Cut Off
Is it in zoom 4:3 or zoom 16:9? Use the left/right arrows to change it.
May 06, 2007 | RCA D52W19 52" Rear Projection Television
Apex Digital AT3208S 32" TV Logo
247 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
