Question about HP Pavilion xl756 (P1358A#888) PC Desktop
Remove front cover on hp pavilion xl756
Remove hard drive
  • 397 Answers
SOURCE: Removing Hard drive from HP Pavilion a1010n
The drives come out through the front of the case, meaning you have to take the front off.
This is a link to the upgrade manual for yout machine, you will nned a pdf reader like Acrocrap to view it.
http://h10032.www1.hp.com/ctg/Manual/c00311110.pdf
Posted on Jul 30, 2008
joecoolvette
  • 5660 Answers
SOURCE: how do i remove the
1) Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, computer on a table, computer case open.
TOUCH the metal fame of the open computer case to relieve your body of Static.
Also before you take new hardware components out of their anti-static bags, or boxes.
If you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
HP Support > Pavilion Media Center a1320n > Opening the computer case
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00593575&cc=us&lc=en&dlc=en&product=1818050&tmp_track_link=ot_search
Replacing the Harddrive, (Hard Disk drive),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639788&cc=us&lc=en&dlc=en&product=1818050&tmp_track_link=ot_search
The Harddrive is a SATA harddrive. Uses a SATA 7-pin data cable, and a 15-pin SATA power cable.
http://en.wikipedia.org/wiki/SATA
Top right photo shows the SATA data cable connector, and cable.
Top right photo below it shows a typical SATA data header (Connector) on a motherboard.
Typical SATA power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a connection for a standard 4-pin Peripheral power cable, (Misnomered as Molex), AND a connection for a SATA power cable, ONLY use the SATA power cable.
It will Burn Up the Harddrive if you use both.
If you are putting a new Harddrive in, you will need to have backed up, (Copied) the info you wish to save off of your old Harddrive, first. This is if the harddrive is not bad, of course.
You will also need the Restoration Disk/s to install a new Harddrive, if you are going to just replace the harddrive with a new one. (Larger, or replacing a bad harddrive)
If you do not have the Restoration Disk/s you can obtain them from HP Support.
In the US call 1-800-474-6836
24hrs a day, 7 days a week.
Disk/s are free. Shipping and handling is not.
$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Have the Serial Number from the back of your computer tower handy to give to the representative.
(White Service Tag. S/N is Serial Number)
If you are not in the US, here is the Worldwide Support contact page,
http://welcome.hp.com/country/us/en/wwcontact_us.html
If you are going to install a new operating system, per se Windows, (Windows 7?), you may have to go into BIOS Setup, and in Boot Order set the first boot device to CDROM, if the disk does not automatically load.
Posted on Oct 24, 2010
  • 34 Answers
SOURCE: I want to remove the hard drive from an HP
Make sure your computer is turned off.
Open up the case.
The hard drive will be hooked up with two cables, a power cable and a data cable.
Unplug both cables, unscrew the mounting screws, then pull the hard drive out.
Posted on Mar 05, 2011
SOURCE: how do i remove hard
After taking off the side panel, remove the front cover. Lay the computer on its side, remove two screws on the top of the metal cage (expansion by) take a long flat head screwdriver and insert it in the cage where the expansion bay is, press down and slide the cage over. Remove power and information cables from the back of the hard drive.
Posted on Sep 23, 2011
Remove hard drive from HP Pavilions a6230n
No you have to remove the media drive cage from the front the panel comes off. then pull on green tab to remove it completely then you'll be able to reach the harddrive
Dec 06, 2012 | HP PAVILION A6230N DESKTOP PC
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
How can I remove the hard disk for an HP Pavilion N5445 notebook?
On the bottom of the laptop there are two covers the smaller one is the memory the other is the hard drive. Shut down the laptop and remove the battery then remove the small screw and you will see the hard drive. You can then remove it; there may be another screw holding the bracket and there are few cables.
Thanks for using FixYa
Jul 04, 2011 | HP Pavilion N5445 Notebook
How do i remove hard drive from hp pavilion m9400f
Dec 31, 2010 | HP FK790AA Pavilion Elite m9400f Desktop...
How do you replace a hard drive in a HP Pavilion -Model 8674D?
The instructions for removing the back cover or front cover might be in the Owner's manual. You need to remove the access panel and once you remove it just uncrew the old hard drive and install the new one and recoonect the wires.
May 25, 2010 | HP Pavilion (PN153AAR) PC Desktop
Removing the cover to get to the hard drive on a pavilion n5415
flip your computer over, use a screw driver to get the top off
suggestion- wear surgical gloves--best not to touch the hard drive
on a laptop, you sometimes cant expand the hd because the box is too small
Apr 24, 2009 | HP Pavilion N5415 Notebook
Bad hard drive on n5350
Most laptops keep the hard drive on the bottom side. There is a cover screwed over the area with usually 2 screws, the cover is identified by the typical 3 disc stacked symbol. In some cases the hard drive slides out of the side, still being held by two screws, some even slide of the front and you must remove 2 rubber stoppers to uncover the screw holes. Each location usually has the hard drive symbol I described eariler. Hope this helps!
Dec 16, 2008 | HP Pavilion N5350 Notebook
Jul 30, 2008 | HP Pavilion a1010n (PS563AA) PC Desktop
HP Pavilion xl756 (P1358A#888) PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
