Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Need driver for Acomdata HD250UHE5-72
Need to download a driver for this backup drive
SOURCE:
SOURCE: External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Posted on Aug 29, 2008
geokohler
  • 304 Answers
SOURCE: backup question
Once you save the data on the external drive it will stay there until you delete it from the external drive. I personally run (2) 1 terabyte external drives and I save My data on 2 separate drives. I have had them fail in the past. This is the only way to ensure you will always have a good copy no matter what. At the time I had only 1 500gb external hard drive and it was nearly full. I bumped it when it was running and lost every thing I had! With the low cost of external drives I recommend buying two of what ever capacity you require and making redundant backups, this will assure you your data will be safe. If you have any other questions feel fre to contact me at [email protected] Send me your number and I will call you for free. I do this for a hobby just to help people. Please take the time to rate this fixya for me and I will assist you with any problem you have. Thank You,
George
Posted on Aug 31, 2008
zzptichka
  • 95 Answers
SOURCE: Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Posted on Nov 03, 2008
  • 13434 Answers
SOURCE: My Acomdata (HD250 UE5-72) external hard drive isn't working
The hard drive is probably faulty, how is the drive? if it uses a external powersupply the power adapter may have worn out and is not providing enough power for the drive to function.
Do you hear clicking from the drive?
A possible solution would be to remove the hard drive from the case, note that it may void your warranty if its still on warranty. And connect it to your computer directly to see if it functions.
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: acomdata HD500uhe5-72 cant be seen . on XP
Try rebooting the computer first with the drive not connected to it.
After the computer reboots, make sure the accomdata is turned off then connect the usb cable. Then turn it on and you should get the password dialog box and be able to access it.
Posted on Apr 21, 2009
Cannot RESTORE data!
Right click my computer...go to manage...then to disk management. What is the status of your disk? Is it online?
Feb 03, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Trouble with my Acomdata external hard drive and my mac
Unfortunately it seems that Acomdata is no more on businness.
In order to get support you can try writing an email to [email protected]
Feb 04, 2013 | Acomdata Computers & Internet
Need software for acomdata windows xp
http://download.cnet.com/acomdata-storage-device/3000-18493_4-95000.html
http://download.cnet.com/acomdata-multi-flash-class/3000-18493_4-73429.html if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
eg: acomdata
you might have to try a few times to get it right
hope it helps
Jul 19, 2012 | Acomdata Storage Device
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Need user manual where can i find online
User’s Guides - English
HybridDrive User’s Guide (PDF: 3.1 MB)
PushButton Backup User’s Guide (PDF: 800 KB)
or go to the Acomdata web site, download in Adobe
http://acomdata.com/hdp/fs.htmlManuels des utilisateurs – Français
HybridDrive (PS-HDxxxUHE5-72) (PDF: 3.2 MB)
PushButton (Sauvegarde à bouton-poussoir) (PDF: 1.2 MB)
Aug 08, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My failed backup Acomdata HD
I have the software you need. Send me your E-mail address and phone number and I will finish fixing this for you free. I will even send you the software for retrieving your data. Don't panic.
George
Jul 21, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Redemption Backup crashes
I have the same problem and have asked Acomdata several times how to fix it.  They say they'll get back within 3 days, but they never reply, Acomdata doesn't support their products.  Buy something else.
Sep 19, 2007 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
269 people viewed this question
Top Acomdata Computers & Internet Experts
Ekse
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
