Question about Technics Audio Players & Recorders
I have no sound when i hooked up my technics sa 404 receiver
SOURCE: Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Posted on Sep 30, 2008
  • 4234 Answers
SOURCE: Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Posted on Feb 18, 2009
  • 36 Answers
SOURCE: Dish Network Box, Technics Receiver, RCA LCD TV connections
I would use the s-video out & red & white rca audio out on dish box to s- video & audio in on the t.v., then audio out from t.v.(RCA, red & white) to one of the inputs (RCA) on the receiver.
Posted on May 25, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
Can i hook a amplifier to my technics receiver model no sa-ax720
If the Amplifier has more Output Power and Better Quality Sound then it is worthwhile to do so -Yes you can connect Amp to Technics Receiver you have mentioned
Jun 24, 2015 | Technics Audio Players & Recorders
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
Dec 04, 2009 | Technics SA-AX530 Receiver
In-adequate User's Manual
That connector passes through your full audio to a compatible receiver.
Unfortunately your SA-EX 310 does not have a coax digital input.
Most new receiver do so if you buy a new one you should be all set.
Aug 27, 2009 | Televison & Video
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
Apr 06, 2009 | Technics SA-AX720 Receiver
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
Technics SA-AX720
Look for lossing solders points or bad conections. Start to look on those components of hi wattage and components to get hot alot, those are the most common to have weak solders spots.
Also some equipment need to be clean because the dust can make problems.
good luk.
May 21, 2007 | Technics SA-AX720 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
80 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
