Question about Proview PL926WBi 19" LCD Monitor
Proview 926 wbi monitor
I was reading a post of a people who had simular problems with their monitor in that the screen would go white and the blue light would stay on.
Read the suggested fix on the power supply board i.e. replace the capacitors. My question is that it displays the screen correctly for about 4 seconds then goes black with sometimes the power led is blue and sometimes goes to amber. Any suggestions ? I have not replaced the capacitors yet.
Thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Proview Master
  • 848 Answers
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 000 170DTLBMH PI 190DTLB Proview 899 AB0 220DTLB PCTH Power Supply...
Posted on Nov 11, 2014
    Problem Solver:
  • 6 Answers
There are online repair shop on eBay where you can send in your boards for repair. Just do a search on "PL926WBi" and you will find seller offering repair service. Sometimes its more then just replacing capacitor to resolve the problem.
Posted on Mar 21, 2009
  • 558 Answers
Have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
My proview pl 926wbi comes on with a black screen and a no signal message then shuts off.
Check that the cable is firmly connected and plugged into the right connection on the computer. Make sure that the monitor is reading from the right input, (i.e. if it's a blue connection it should be set to VGA/Analog, if white then it should be DVI/Digital) or at least set to Automatic.
This can be configured on the monitor by pressing its' Menu button.
Feb 28, 2011 | Proview PL926WBi 19" LCD Monitor
I have a Proview PL716S and sometimes the entire
ur monitor got err i need to be changecoz repairing of monitor is unprofit
Apr 14, 2010 | Proview PL916S2 Monitor
Monitor proplem
That sounds like either bad VGA cable or cable is not seated properly into the monitor or the PC. Try that first. Try it on another PC also. Just need to narrow down the problem. Please post back.
Apr 13, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
Proview 15" screen turns white
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring it to an authorized service center. best regards
May 22, 2009 | Proview PL916S2 Monitor
Dead Proview 700p monitor
my monitor samston 17`` have a problem with screen ten minute after on it`s become on / off screen ( it`s black, it`s white ) when it`s happen the wording can read, when it`s on.
Jun 25, 2008 | Computers & Internet
Proview PL926Wbi LCD Monitor White Screen
I found in the refuse, a Gateway FPD 1520, 15" LCD monitor that started off losing the screen half-way, losing sync, etc. The "mechanical agitation" method was applied and remedied the problem. Awhile ago, it went to a white screen (or, as it was back in the day- a clean raster). I opened it up and found that the ribbon cable on the left was loose. I applied a series of layers of adhesive-backed foam (the kind you stop drafts in your home with) until it was greater than the height of the metal enclosure to put pressure on the unbehaving connector. It does seem a bit loose and this will keep it snug. Maybe hot glue or other adhesive if it wiggles loose again. Seems to have solved the problem at the moment.
Oct 15, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
243 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
