Question about GPS
Wiring vhf model gx1260s to lowrance hd5 gen2
Like a wiring diagram to hook to a chartplotter
2 Suggested Answers
SOURCE: chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Posted on Jun 22, 2009
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
'isn't working' is such a broad problem. If it is only the GPS, it is covered from Page 49 of the manual and shows you can access Satellite information. Note, it almost certainly won't work in your garage or storage. It need to see the sky as the antennae is internal.
The unit has an installation guide. In my personal opinion, it is better to let a professional boat engineer install it, mainly for the correct fitting of the transducer on the stern. Correct placing makes all the difference to a good set up, unless you intend to fish without the engine running.
All they need is mounting, power through a fuse direct to the battery, and the transducer fitting. Then you put the boat in the water and switch it on.
Installation Guide
http://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-5-SERIES_IG-MT_988-11024-001_w.pdf
Manual
https://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-SERIES_OM_EN_988-11004-002_w.pdf
Full Specs
HOOK 5 Fishfinder and Chartplotter
Apr 24, 2017 | Lowrance GPS
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
How to set up overlay data on a touch 7
HDS 7 Gen2 Touch Touchscreen Fishfinder Chartplotter
this is a link so you can download a PDC file of your operators manual.
on your has 7 push the pages button on the upper right hand corner of your unit. Then refer to page 18 of your manual to change your overlay data.
This should get you headed in the right direction.
Aug 01, 2014 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Jun 11, 2014 | Lowrance Boating
HDS Gens Touch shows positive red to negative & black to positive?
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Jan 05, 2013 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Jun 29, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
GPS Logo
27 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
