Question about Whirlpool Refrigerators
French Door Refrigerator Model #G17FVCXWY icemaker stopped working
Does anybody know how to fix this
5 Suggested Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
mark_37388
  • 100 Answers
SOURCE: kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Posted on Mar 30, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
We recently replaced the icemaker in our samsung french door refrigerator,the icemaker worked fine for a few days and now no water goes into it,, we replaced the filter as well
Hi my name is Sean, you will need to check water pressure going into refrigerator, If you have adequate pressure, you either have a bad main board, or bad valve, depending on the year the boards were a problem in this unit affecting the icemaker especially. Let me know if you need further assistance.
Mar 26, 2011 | Samsung RF265AA Bottom Freezer French Door...
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
Ice maker motherboard
call the manufacture, sounds like an issue with the circuit board
Feb 19, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice maker fails to make ice tried several times to turn switch on and off water flows to the cold water dispenser worked OK for the past several months what to do??
I hate to say this but from experience on LG icemakers if the fingers aren't turning or the if you have the flextray model the only fix is a new icemaker. Make sure the fill tube to the icemaker is not frozen also.
Oct 23, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
161 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
