Question about Kenmore 44102 Front Load Washer
Kenmore Front Loading machine, does not drain the fabric softener
I have a Kenmore Front Loading machine and for some reason the fabric softener has stopped draining. The same amount of fabric softener has been in there for a few weeks now, so I don't think that any water is washing it into the machine.
  • 6 more comments
  • bigben100 Feb 21, 2008
    fabrick dispensor does not drain .how does it work. ive cleaned it out thourry but it still does not drain. benyancey1@hotmail.com
  • chimeygirl Jan 12, 2009
    I have the exact same problem with the fabric softener not emptying. I've cleaned out the tray and inside with a toothbrush, but that did not help. I will try the water line suggestion. Thanks!
  • Anonymous Mar 14, 2014
    When I put fabric softener in and run a load the softener doesn't drain into the washer
    can you dye fabric in my cabrio top load washing machine
  • Anonymous Mar 18, 2014
    Fabric sofener won't drain into washer, Front load machine
  • Anonymous Mar 22, 2014
    Why doesn't the water drain out of the softener bin that is next to the soap bin in the drawer? Even if I don't use any softener there is still water in that bin that doesn't drain out.
  • Anonymous Mar 25, 2014
    A+ nano technology full automatic front loading washing machine. A+ letters are shining when we put on the supply and no water supply. I checked the water line it is okay. what is the reason?
  • Anonymous Mar 28, 2014
    water s f
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Posted on Oct 28, 2006
    Problem Solver:
  • 5 Answers
Remove soap dispenser tray and clean tiny holes in top of cavity
Posted on Aug 16, 2007
My kenmore washer model number c47192 will not let the fabric softener drain. I have washed out the dispenser area throuroughly but it will not go through. Someone please help.
Posted on Mar 07, 2010
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
I have a front load Kenmore HE3T washer that is beeping and flashing a F3 code. I cannot get the machine to shut off with the pause/cancel button and had to unplug it...can anyone help me. Thanks
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing Machine Mod. 11020052994 will not wash on heavyd
Jun 17, 2009 | Kenmore Washing Machines
Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
May 23, 2009 | LG WM1814CW Front Load Washer
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
Aug 21, 2008 | Kenmore Elite 45986 Front Load Washer
MY 90 WERIES KENMORE WASHING MACHINE FABRIC SOFTENER DISPENSER DOES NOT EMPPTY
I am having the same issue. I do know that the reason you don't see any physical provision for it to drain is because it is drained using a siphoning effect. water is put on top of the fabric softener until it reaching a point where the siphoning begins. Once the siphoning begins, the whole thing will drain out until there isn't much left (however there will always be a little water left). I know siphoning works with my drawer b/c when I take it out and fill it with water slowly until the siphoning begins, the whole thing drains out. There must be another reason why the fabric softener isn't working.
Apr 27, 2008 | Washing Machines
Kenmore 44102 Front Load Washer Logo
1,266 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
