Question about Water Heaters
I have a Grohe Avensis Classic dual Thermostatic Advanced shower mixer - And although the hot & cold water supplies reach the mixer, the water coming out of the shower head is almost cold. I have taken the mixer off and checked the filtrs - they are clean. I am told the solution could be a new cartridge, but which one and how is it fitted?
  • 34 Answers
SOURCE: little hot water
Is it only in the shower?
Posted on Feb 09, 2009
gary1121
  • 332 Answers
SOURCE: Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Posted on Jun 06, 2009
pipesster
  • 20 Answers
SOURCE: Grohe valve Grohtherm Thermostatic Rough 34-126
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Posted on Jan 25, 2010
  • 122 Answers
SOURCE: my thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
Posted on Aug 15, 2010
  • 1015 Answers
SOURCE: My Grohmix 19 421 thermostatic
The problem might be fixed by removing the cartridge and cleaning it thourghly and resetting temp stop.Yes the cartridge could be bad but new parts are readily available. Depending on water quality conditions in you area it may be difficult to disassemble so it may be a good idea to have a plumber do it for you. Thank you.
Posted on Mar 03, 2011
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
My thermostatic mixer shower will not turn off
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Got a gocta w-26mixer shower bar fitted cold tap
from a plumber all hot and cold connections on all major showers are hot on the left and cold on the right just like the taps on your sink or washbowl
Dec 09, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Water Heaters Logo
15 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
