Question about Ovens
Need wiring diagram of smeg so66ccs-5 oven
Need to know if fan element working, also about noise when oven cooling down after use. thank you, jim orwin
SOURCE: smeg single fan oven
I have the same problem. The oven was working fine until I cleaned it. There was a power failure during the cleaning, but it appeared to function properly until the cleaning cycle finished. I spoke to Dacor customer service and they told me there is a "high limit" switch to ensure that high temperatures do not damage the electronics. They recommended calling a local servicer to come and check the oven and reset the switch. They indicated that the servicer may be willing to tell me over the phone where the switch is so that I could reset it myself. They like to have someone come out just to make sure nothing else is wrong with the oven. Given that there was a power failure in my case, chances are a simple reset will do the trick. You may have a similar situation. If anyone knows where the switch is, it would be good to share on this forum. In any event, I'll call the local service department tomorrow and try to find out.
Posted on Oct 31, 2006
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
  • 49 Answers
SOURCE: Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Posted on Mar 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
The light and fan works but no heat comes on in oven.
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven ss336-5 not heating
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
No heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Jan 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Jun 01, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
