I need a JDI firmware for J7949E V.28.59.FF - any way to extract this from a printer?
  • 4 more comments
  • Justin Check
    Justin Check Oct 28, 2008
    It's for an HP 4250n laserjet but it's also used in other printer boards with integrated NIC cards.
    The newest firmware causes 49 FF09 Service Error to come out repeatedly - and I don't want to break the printer by turning it off and on every time just to go around the problem.
    Here is an excerpt of the HP email support I got - obviously they're offshore support cutting and pasting troubleshooting scripts.
    To answer your questions in order:
    a> no - I would be on the web interface and it will just error out and cut me off. Print jobs go on queue on our server when the printer errors out.
    There are no particular files that will consistently gave error messages.
    b> Yes, some print jobs get cut off midway when it errors out, but continues when we restart the printer. It will not cut off at the same print job at the exact page again if that is what you are asking. Error log just shows 49 FF09 - consistently.
    c> No.
    d> No.
    e> No.
    F> No.
    G> No.
    H> No.
    I> No.
    J> I have the printer besides me so I see when it just goes to error. Random, never when it goes to sleep or some similar. Not timed, Random.
    Always says 49 FF09 Service Error - No other error code at this time.
    Btw, I have 4 similar devices running in the office with no issues. They all have older firmware versions - v28 something. The ones we are troubleshooting all have v3314 now.
    Thank you for contacting Hewlett-Packard's Commercial Solutions Center.
    I would like to get more information on this issue.
    A> Was someone printing a print job when the error was encountered? If so do we
    know who and do we know what they were printing? Is the file or job available for
    testing?
    B> Was an incomplete print job found at the device when the error was discovered? If
    so, do we know who was printing it and do they have the job/file available for testing?
    C> Was someone sending or receiving a fax and/or configuring the device for any fax
    functions on the control panel? If so, what else is known about the fax transmission or the
    functions being configured?
    D> Was someone sending an e-mail or using any of the send to folder, send to ftp or
    send to Workflow options? Were they configuring the device to perform any of these
    actions at the control panel? If so what else is known about the functions being used or
    the configurations being performed?
    E> Was someone performing a copy job or configuring the device for a copy job? If so,
    do we know what type of copy job they were performing or the configurations being
    selected?
    F> Was someone clearing a jam or attaching or removing anything from the device? If
    so how was this being done?
    Page 8 of 25
    G> Was someone configuring anything with the touch screen control or menu selections
    found on the device? If so what were they configuring and what menus here they using?
    H> Was someone using Web JetAdmin or the devices Embedded Web server to
    configure or perform a function? If so, do we know what feature or setting they were
    configuring or action they were performing?
    I> Was anyone using the direct PDF print feature? If so is the file available for testing.
    J> What time of the day are the errors seen on the device? Who was in the office? How
    often have they found the device in the error state? Is it always displaying the same
    error?
    Look forward to hear from you.
    Once again, thank you for contacting Hewlett-Packard's Commercial Solutions Center
    Regards,
    < N.Suresh Kumar>
  • Justin Check
    I'm not sure the support guy know what he's asking the end user to do - I'm definitely more technical than most BUT I think this is what typical people get when they email HP support.
    I would request you remove and replace the user replaceable parts one by one and check if the error message gets cleared, by performing this step you will come to know which part of the printer is causing the issue.
    The following sections discuss user-replaceable parts.
    Print cartridge
    1 Open the control-panel door.
    Figure 6-3 Print cartridge (1 of 2)
    User-replaceable parts 175
    2 Firmly grasp the print cartridge and pull it up and out of the printer.
    CAUTION Do not expose the print cartridge to bright light or direct sunlight for long
    periods of time. This can damage the cartridge, which will result in print-quality defects. If
    the cartridge must be removed from the printer for an extended amount of time, cover it
    and keep it out of bright light or direct sunlight.
    Figure 6-4 Print cartridge (2 of 2)
    176 6 Removing and replacing parts
    Transfer roller
    1 Open the control-panel door and tray 1.
    CAUTION Do not touch the black rubber on the roller. Skin oils on the roller can cause
    print-quality problems. The use of disposable gloves is recommended when you remove
    the transfer roller.
    2 Use a transfer-roller removal hook (callout 1) to lift the left end of the metal shaft out of place
    near the blue gear (callout 2). If a removal hook is not available use a flat-blade screwdriver.
    Slide the transfer roller to the left to remove it.
    CAUTION Be careful to release and lift the left side of the roller first, and then slide the
    roller out.
    Figure 6-5 Transfer roller
    Reinstallation tip When you install the transfer roller, make sure that the black collar on
    the left side is oriented correctly, with the open end face-down (the solid end is face-up).
    User-replaceable parts 177
    Fuser
    WARNING! The fuser might be very hot. After turning off the printer power, allow the fuser to
    cool for at least 30 minutes before removing it.
    1 Remove the rear output bin. See Rear output bin.
    2 Squeeze the blue fuser-release tabs (callout 1).
    3 Pull the fuser (callout 2) straight back and out of the printer.
    Figure 6-6 Fuser
    CAUTION Do not drop or jar the fuser. It can easily be damaged if it is mishandled.
    Hint When you replace the fuser, make sure that it is fully seated into the printer. You should
    hear both sides snap into place.
    178 6 Removing and replacing parts
    Tray 1 pickup roller
    NOTE If the optional envelope feeder is installed, press the release button on its left side
    and remove the feeder. Then proceed to step 2.
    1 Remove the front accessory cover (callout 1).
    NOTE If the printer has an envelope feeder installed, this cover will not be in place.
    Figure 6-7 Tray 1 pickup roller (1 of 2)
    User-replaceable parts 179
    2 Release the pickup roller by sliding apart the latches that are located on each side at the top of
    the roller. Lift the roller (callout 3) out of the opening.
    Figure 6-8 Tray 1 pickup roller (2 of 2)
    Reinstallation tip When you install the pickup roller, place the two pivot pins in the
    lower mounting slots (callout 2) and rotate the roller into the printer until it snaps into place.
    180 6 Removing and replacing parts
    Tray 1 separation pad
    1 Remove the front accessory cover (not shown). See Accessory covers and the tray 2 extension
    door.
    2 Insert the tip of a a small flat-blade screwdriver under the tray 1 separation pad.
    3 Carefully twist the screwdriver to dislodge the separation pad. Remove the tray 1 separation pad.
    Figure 6-9 Tray 1 separation pad
    User-replaceable parts 181
    Tray 2 feed rollers
    1 Remove tray 2 and place it on a level work surface. Locate and open the cover (arrow) that is
    next to the roller in tray 2.
    Figure 6-10 Tray 2 feed rollers (1 of 4)
    182 6 Removing and replacing parts
    2 Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft (arrows).
    Figure 6-11 Tray 2 feed rollers (2 of 4)
    CAUTION When you install this roller, make sure that it locks into place. Verify that the
    roller is correctly oriented, and that the round, black spacer next to the roller is correctly
    positioned against the locking pin on the shaft.
    WARNING! Do not allow the front of the printer to extend beyond the edge of the work
    surface. The printer can become unbalanced and fall, which can cause damage to the
    printer or personal injury to the service technician.
    User-replaceable parts 183
    3 Move the front of the printer to the edge of the work surface for better access to the remaining
    feed rollers. To find the rollers, look up into the inside of the opening that was created when you
    removed tray 2.
    Figure 6-12 Tray 2 feed rollers (3 of 4)
    184 6 Removing and replacing parts
    4 Pinch the blue latch on the left side of the feed roller (two rollers are intslled here). Slide the roller
    off of the shaft. You might need to rotate the roller in order to pinch the latch.
    Figure 6-13 Tray 2 feed rollers (4 of 4)
    5 Repeat the previous step for the remaining pickup roller.
    Reinstallation tip When you install each of the rollers that you removed in steps 4 and
    5, make sure that it locks into place on the tabs that are on the drive gear.
    I replied...
    It seems that you are getting these scripted instructions from a webpage or book. It would be best to send me a link so I actually have pictures to look at - the instructions point to figure so and so - but the email is in text.
    I also want to know the end game - as we are starting to delve deep into VERY technical territory here and I do not want to accidentally break anything while following the instructions.
    It seems to be a known problem from your HP FORUMS. We have 2 different machines that have the same exact problems that happened around the SAME time.
    I tested print driver installation on a separate server and this did not fix the problem, but I have eliminated the possibility that it is our server causing the problem.
  • Justin Check
    My last reply never got an answer back... this is the state of HP email support these days....
    Please provide a download link to older firmware version for the 4250dtn.
    LESSON LEARNED:
    IF YOUR 1 YEAR WARRANTY EXPIRED, YOU WILL TYPICALLY NOT GET ANYWHERE WITH THESE EMAIL SUPPORT ISSUES GOING THROUGH HP. DELL GETS MY VOTE ON THIS AS THEY WILL STILL HELP YOU GET THINGS DONE - THEY SUGGESTED THIS WORKAROUND THEMSELVES AND I TRULY APPRECIATE THEIR CANDOR.
    I WOULD ENCOURAGE YOU TO GET A SIMILAR MODEL SERIAL NUMBER THAT IS STILL IN WARRANTY - AND GO WITH TECH PHONE SUPPORT CALL FROM THERE AND PRESENT THE SAME ISSUES, YOU WILL GET OVER THE FRONT LINE DEFENSE OF TIER 1 SUPPORT TO TALK WITH AN ACTUAL TECHNICIAN WHO CAN GIVE YOU MORE OF A CHANCE TO SOLVE YOUR PROBLEM.
  • Justin Check
    Justin Check Oct 31, 2008
    RESOLVED WITH A JDI FIRMWARE DOWNGRADE!!!
    http://www.euroform.com/english/faq/defa...
    You can download JetDirect firmware V28.54 here.
    http://ftp.euroform.com/download/emulati...
    My last reply to my HP Case...
    Your case email was accepted. CASE_ID_NUM: 36035482xx
    You and HP are dead wrong.
    Everyone out there should stop reading textbook scripts and go back to real world training.
    I consulted 2 technicians and they both said HP would not recommend downgrading - and never gave older firmware to try.
    Let me be clear - Going back to v28 firmware fixed the problem.
    Both printers are running fine since. I had to spend a lot of time looking from European forums to get the driver.
    STOP UPSELLING US ON WARRANTY REPAIRS!
    I'LL BE NICE AND NOT SAY ANYTHING BAD ON THIS TICKET - BUT REST ASSURED I'M THINKING IT!!!!!!!!!!!!
  • Justin Check
    Justin Check Dec 04, 2008
  • Anonymous Apr 07, 2009
    The same problem here with HPLJ2430 and Jetdirect FW 33.15. Sporradicaly 49.FF04 error. I think its a problem with the DHCP client in the new Jetdirect FW.
    Thank you very much for posting the link to the older FW! :-)
I need a new Firmware Samsung CLX 3185fn
  • Download Link - http://sbx.sk/ADaN
  • Download and save Samsung reset tool for CLX-3185 to your harddisk
  • Extract compressed file.
  • Turn on your printer
  • Drag and drop file *.hd to usbprns2.exe or simplest double click ondownload.bat
  • Wait for re-flashing firmware complete
  • Restart your printer.
Do not turn off printer while reflashing firmware. It might damage your printer and might be it can't be recover anymore. Do the work with risk!
Aug 01, 2014 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Lipi6306 matrix printer not going to offline mode always in online configure 1
step 1 : change the panel cable
step 2 : change the control panel
step 3 : download firmware as follows :
T6306 FIRMWARE DOWNLOADING PROCEDURE
  1. Connect the printer to pc through parallel port.
  2. Press "FF + ^ + CONFIG" at the control panel and power on the printer .
  3. Panel will show "ready to download".
  4. In dos mode type "vdv3000r -pb" and enter .
  5. After completing the firmware loading printer may show NVRAM fault.
  6. Press "CLEAR"and printer will restart to finish.
Mar 02, 2014 | Tally Line Matrix T6050 Printer
How download hp2420dn printer driver directly on usb to use it to other computer which attached to 2420dn
Go to the following link. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=412132&lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&taskId=135
Click which operating system you need the driver for. Scroll down and download the driver for either PCL5 or PCL6. If its basic printing either of those will do. Save the .exe file to your USB drive. Connect USB drive to other computer. Run the file. Select a location on the PC ex. C:\Documents and Settings\"Username"\My Documents. Click unzip. This will extract driver files. To add these printer drivers go to Start > Printers & Faxes or Devices and Printers if its Windows 7. Click add printer select local printer attached to this computer. In the drop down menu select USB001. If you have different devices using USB you might have to repeat the add printer step until you find the right USB name. Once on right USB port click next and this is where you will click Have Disk in bottom right hand corner then click Browse. Go to the directory where you unzipped the printer drivers. Click on any of the .inf files. This action should bring a dialog where you can select a printer or it will just install. Click if you want to share or not share then hit next then if you want to print a test page (I would) click that. Click Next then Finish and your printer should be working properly.
-Ben
Dec 31, 2012 | HP Laserjet 2420dn Laser Printer Duplex /...
Hp 2420 offline error
Upgraded all jetdirects to their latest firmware, DOWNgraded any jetdirect J7949E on firmware v33.15 to v33.14 (.15 is horribly broken and crashes after a couple of minutes usually).
I have enabled SLP protocol on all the print servers, I have then telneted into the jetdirect to set slp-keep-alive (available with the firmware updates) to a value of 2 (2 minutes between slp anouncments).
I have changed the MAC age time on all the switches to 900 seconds from the default 300.
Jetdirects now announce themselves every 2 minutes stopping the switch forgetting that they exist. I have added a logoff-period of 1800 seconds to a single port with a Xerox printer on it which stops it reauthenticating every 10 minutes (unable to change slp interval on it).
This may or may not help, but I've had the printers on line for the last week now and when I ping, they are still there!
Jul 22, 2012 | HP LaserJet 2420 Printer
Hi i have a problem to my persona c30e printer, it prints but the image is too blurry? is it normal to the printer making that laud noise.
Welcome to FixYa!
Solution to loud noises:
Check the ribbon cartridge and ensure that the cleaning roller is properly installed and rolls smoothly
inside the cartridge. Then check the plate underneath the cleaning roller and verify the 4 pins are seated properly.
Solutions to blurry prints:
1. Make sure the printer has the latest firmware via the web. >> Click Here << to download the latest firmware (Look for "Persona C30e Firmware_Windows/Linux 4.3.0.1 "). The firmware upgrade file is packed in zip file. Extract it to a directory of your choice.
>> Click Here << for an instruction on how to upgrade the firmware. When being prompted to locate the "upgrade file", browse to where you extracted the firmware upgrade file.
2. Calibrate the ribbon sensor. If you have completed these 2 steps and the printer still prints out faded or light cards,
3. Try a new power supply. Part# (E000480). Note: Please verify the proper power supply is being used.
Thank you for using FixYa!
Dec 19, 2011 | Fargo Persona C30 Thermal Card Printer
49.FF 01 Service Error
error 49 indicates Firm ware.. Up load the firmware,if not happening replace "formatter"..
Sep 14, 2011 | HP LaserJet 2420 Printer
HP M2727nf laserjet.Firmware courrpt on display .printer locked up
The error is due to corrupt firmware and you need to reinstall it.
HP M2727NFFirmware & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
Extract of the instructions for Firmware Update from Hp Official Site is as under: -
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the M1522_MFP_Series_FW_Update-20100902.exe. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
  11. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100902.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 03, 2011 | HP Office Equipment & Supplies
HP 4014n error 49 ff 04
Printer has a critical firmware error.
Turn printer off and then on. Press STOP to clear the print job from memory.
Turn it off and on again. Print something from a different application. If it works. Go back and try and print the failing document. If it fails again, that app is bad.
You might want to go to www.hp.com and download the latest firmware for you printer.
Mar 02, 2011 | HP LaserJet P4014n Printer
865 people viewed this question
k24674
