Question about Whirlpool duet Dryers
How do I install a dryer rack inside a GE DRYER?
SOURCE: Dryer Rack
The dryer rack is shipped in place in your dryer. Remove and
discard any packing material before use.
Use the TUMBLE FREE Heated Dryer Rack for items that you
do not want to tumble dry, such as sweaters. When you use the
heated dryer rack, the heated air inside the dryer flows in a
concentrated pattern to allow efficient and uniform drying.
Use Timed Dry to select the desired time.
NOTE: Do not use Auto Cycles with the dryer rack.
To use the heated dryer rack:
Do not remove the lint screen.
1. Open dryer door.
2. Place dryer rack over the bottom of the dryer door opening.
Rest the back wire on the dryer back ledge. Push down on
the frame front to secure over lint screen.
3. Place wet items on top of the rack. Allow space around items
for air to circulate. The rack does not move, but the drum will
rotate. Make sure items do not hang over the edges or
between rack grille.
4. Close the door.
5. Select TIMED DRY and MORE TIME or LESS TIME. Reset
time as needed to complete drying. Refer to the following
table.
6. Select the desired temperature setting to match the fabrics in
your load by pressing TEMPERATURE. Items containing
foam, rubber, or plastic must be dried on a clothesline or by
using the Air Dry temperature setting. Refer to the following
table.
7. Start the dryer.
NOTE: You must remove rack for normal tumbling. To remove the
dryer rack, lift it straight up and out of the dryer.
NOTE: Check the lint screen and remove any lint accumulated
from items dried on the rack.
Suggested Items for Rack Temperature Suggested
Drying Setting Time*
(Minutes)
Washable wool items (block Low 20
to shape and lay flat on
rack)
Stuffed toys (cotton or Low 20
polyester fiber filling)
Stuffed toys (foam rubber Air Dry 50
filled)
Galoshes (rubber) Air Dry 20
Foam rubber pillows Air Dry 50
Tennis shoes Air Dry 20
*Reset time as needed to complete drying.
You can get all of this and pictures at www.managemhome.com.
Posted on Dec 11, 2007
  • 686 Answers
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Posted on Feb 17, 2009
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
  • 236 Answers
SOURCE: How do I install a dryer rack in my Kenmore Oasis
The rack goes in thru the door and rests on the back panel usually in small slots and just behind the door.
Posted on Sep 18, 2009
  • 32 Answers
SOURCE: HOW TO INSTALL BELT FOR GE DRYER
Take the top off. There will be 2 screws on each side where the front is hooked to the body. Unscrew them. The whole front comes loose along with the drum. Put the belt around the roller and under the roller support, then around the drum. Was easier then you thought huh.
Posted on Oct 10, 2009
How to install dryer rack in kenmore HE3 dryer
Open your Kenmore HE3 dryer door. Look for the ledge on the inside rear of the dryer wall.
Insert the rear wire leg of the dryer rack into the drum, resting the wire leg on top of the ledge. The front frame should rest over the dryer lint screen.
Push down on the top of the front frame of the dryer rack to secure it over the dryer lint screen frame. Close the dryer door once you load your items on the rack.
Feb 02, 2013 | Kenmore Dryers
I cannot figure out how to place the dryer rack.
Try here.
http://www.devicemanuals.com/guide/Dryer/Kenmore%20Elite/Kenmore-Elite-11067052600-Residential-Dryer-Use-and-==TWpjM01URTM=.html
Sep 13, 2009 | Kenmore Elite HE4 Electric Dryer
How do I install the drying rack. i have never used it and can't find my manual
i dont have your model # , but on most models you take out lint filter and pu the rack inside the dryer drum.the one end of the rack that looks like it goes into something goes into the filter housing. hope that helped you ....
Sep 13, 2009 | Dryers
New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
May 29, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
GE Profile Performance Dryer
GE Easy care 4 prong Installation
Grn = Ground
White = Neutral ?
Black = ____ top or bottom?
Red = ____ top or bottom?
Please advise
Aug 19, 2008 | GE Profile Harmony DPGT750EC Electric...
Install shoe drying rack gas dryer
I am in dire need of the Fisher & Paykel Dryer rack Model # DEGX1. I now have a two year old who loves Mud puddles and I would love to be able to buy the Dryer rack. If you know where I could find one. could you please contact me @ heatherys@yahoo.com
Mar 22, 2008 | Dryers
Dryer rack installation
I had the same problem: they sent me the rack, but no instructions.
But if you look in the product manual for your dryer, there should be a section on how to use the rack. For the Cabrio, which is what I have, it's on page 21.
If you don't have the manual anymore, you can get them online at Whirlpool's web site. Just plug in your model number in the search box, and there it will be.
Feb 26, 2008 | Whirlpool Cabrio WTW6600SBK
Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Dec 09, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
2,072 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
