Question about KitchenAid Kitchen Ranges
Error F6E0, Lost communication
I have kitchenaid E150072SP and just stop working with error code F6E0, Lost communication
4 Suggested Answers
SOURCE: F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Posted on Nov 27, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: KITCHENAID KGRS807 ERROR MSG F6E0
Problem with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Posted on Feb 22, 2009
espressonist
  • 1711 Answers
SOURCE: lost communications error code F6E0
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control.
Posted on Oct 04, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error code F6E0 on Kitchenaid KGSS907000 wondering if it is the control board or touch screen, what other components could cause this?
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control board
May 02, 2014 | KitchenAid Architect Series KEBC107KSS...
Oven does not work is reads F6E0 error code lost communition what's wrong?
I assume it's a KitchenAid that you have. Here you can find a previous thread about this code:
http://www.fixya.com/support/t1176150-f6e0
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Ovens
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
Lost communications error code F6E0
Sep 10, 2010 | KitchenAid KESS908SPS Electric Kitchen...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Feb 22, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
F6E0
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchen Ranges Logo
59 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
