Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Bissell proheat 12 amp
The front end is dragging on the carpet. Have taken out and replaced both windows and still is dragging. What am I doing wrong? When this is going on there seems to be no suction though when I put a piece of paper under it when it's standing upright I have suction. HELP!!!
Donna
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gsshg
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I need a diagram of the hose connection in a Bissell Proheat model 1699-r
Bissell Proheat Carpet Cleaner Parts & Repair Diagrams
www.vacpartswarehouse.com > BISSELL
The Bissell Proheat Series Vacuum Parts, Repair Schematics, & Accessories. ...Bissell Proheat Proheat Cleaner 25A3 ... Bissell Proheat Deep Cleaner 1699 ..
Aug 30, 2015 | Bissell Vacuums
Now I know why the bissell is dragging. There is no middle position on the handle. There is either upright or low (for under furniture) What can I do?
Hi Eva! If your machine is dragging on the carpet, one of the clear nozzles on the front may be off alignment. Here's a link to our FAQ to help you with the dragging: http://www.bissell.com/FAQDetail.aspx?id=1102&cid=ccsocial
Sep 05, 2013 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat snags on carpet
Hi Richardad229. The front clear window nozzle(s) may be off alignment and can be re-aligned quite easily.
Here's a link to the instructions: http://www.bissell.com/FAQDetail.aspx?id=1212&cid=ccsocial
Apr 20, 2013 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 12 amp turbo carpet cleaner, not sucking water, model#8910
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My Bissell Proheat 12 amp is hard to push forward(whether on or off). There is a loud clicking noise when pushing forward and it ''jumps'' up on every loud click. It's OK when pulling backwards, sprays and...
I had this same problem and here is what solved it for me. On a previous cleaning session, my wife decided to take the two front screws out of the clear plastic shroud that covers the brushes in order to clean behind it. Upon re-installation, she did not secure the top part correctly. On the end near the water tank, there are two tiny half-moon tabs that absolutely need to be seated in their opposing slots in the chassis.This allows for a good seal which enables the machine to **** up the water. It also keeps the front cover level and from dragging on the carpet when pushing it forward. Both were problems I was experiencing. Hope this helps!
Mar 09, 2009 | Bissell 1699 ProHeat Clear View Upright...
Scotchgard for Bissell Proheat 12 amp carpet cleaner model 7901 1
heatman101
hbn
Jan 27, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
176 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
